DEEPERS
  • #76
    Originally posted by georgi.g.zhelev View Post
    Georgi can you give here more clear pic of power supply? I am wandering about C1/14? Is it 10uF? What is it's orientation on pcb? Kind a uncommon way to wire up 7660? Is it wired as voltage doubler? There is certain disparity between your PS hand draw schematic and pcb... or i just can not see clear pin numbers on 7660!?
    • #77
      no... they are aluminium also here!
      I'm drinking 7up right now... it's good aluminium stuff... maybe , one time, it was some B52 fuselage....
      Just BS products use iron/steel for beverage stuff.... unless needed (e.g. large containers).
      Kind regards,
      Max
      You should try using a magnet on the side of a cola can, its magnetic, has been for many years. The top is aluminium.
      I know this post is a few years old.......but I could not leave it as it was....sorry.
      Andy
      • #78
        Hi, Ivconic, sorry for the delay. I tried to draw a scheme to supply DEEPERS-8, this happens:
        • #79
          DEEPERS-8 P.S.
          50% Size:
          • #80
            • #81
              DEEPERS 8 P.SUPPLY
              DEEPERS 8 P.SUPPLY NOTE: LM2940 pin 2 connection pin3 LM2910!! Sorry for the mistake.
              • #82
                Don't worry; mistake is my middle name!
                • #83
                  hi all,
                  can anybody share a photo of Deepers 8 inside? got Deepers 10DD in repair and would like to compare. The PCB of 10DD looks very similar to the schematic in the thread.
                  give my regards to your wife
                  • #84
                    • #85
                      hi all,
                      Hi kt315. Did you repair Deepers 10DD? What is the impression left on you - how it works Deepers 10DD?
                      • #86
                        I am interested in how discrimination. If you have a device, it is possible to compare the scheme with the PCB. I think that there are errors in the scheme. And so, all the paint and make a new, proven design. Thank you, Anatoly!
                        • #87
                          in a process... will tell you as speedy as I will fix it.
                          • #88
                            can anyone give an instruction manual on deepers 10 dd? do not find it at their site.
                            • #89
                              Maybe it'll help you "User Manual Deepers X5"... http://www.metaldetection.net/English/Portal-Eng.html
                              • #90
                                thanks Maikl. may you have a manual on Deepers 8? Deepers 10 DD is same like it, there are only some diffs in values, power supply on TS555 (~NE555) etc.
