DEEPERS
    Hello Nelson ,
    The schematic is 100% functional from original ,is my contribution for 2009....
      Hello
      Maybe 1836 help for HEX for thiz Schematic.
      Best Wishes
      Erol
        Hi afl.
        I have the pictures, so when a get home i ll post them.
        I also like to know if the schematic is the correct one or have any problems
        Nelson
        Hi Nelson
        How are you ? Waiting for you pictures .
        About circuit ,theory seem is correct . but exactly Alexismex know.
        Best regards.
          HiAlexismex
          For circuit thank you . can you upload some pictures from inside the box ?
          Best regards.
          HiAlexismex
          Waiting……………………
          Best regards.
            Hi Alexismex and thanks for anwer my question.
            Do you have the pcb design to share?
            A friend of mine, send me a few pictures of deepers 8. Last evening i had the intention to send them has i promess here, but a last inconvinience didn´t allow me to do that. So Aft this evening i´ll try to send it.
            Alexismex, can you lease tell us how is the performance of this detector?
            I had heard from my friend here in Chile, that this detector doen´t work has is advertise from the factory. Any comments will be very helpfull.
            Take care and i hope we can feedback from your expirencies.
            Nelson
            PD: my email is ce3llp@mi.cl
            Originally posted by Alexismex View Post
            Hello Nelson ,
              battery configuration for deepers 8
              dear friend alexismex thank you for sharing this circuit and what the configuration of the battery for this circuit +6volts and -12volts .
                Soon i will post the power supply i must draw from paper to Splan,
                I do not have actually a camera...later .
                For the performance very good in neutral soil... with 10 inch coil.... air test 85cm .... inside ground 70 cm.for a alu-coca-can ....much much better than pulstar....If you see the schematic ...you will see a small " Deeper-secret" to give the punch for the sensibility ...you must use + 6v and -12v for the Op's.... if you go to a more conservative approach with +5V and -5 V or 6 and 6 you will loose easely 10cm for the alu can and proportional with bigger coil ....
                have goods feeling all the forum.
                  Hi Alexismex
                  Thanks very much for the schematic. I have a question. Q 16 is a reg. volt. of 2.5 V? 2.500 V in schematic.
                  Esteban
                    DEEPERS
                    Alexismex , Thank-you for the beautifull schematic !!! Almost as beautifull as yesterdays photo of Miss India that was deleted . I found a link with depth information just scroll to the bottom of the page !!
                    Please show pictures of the circuit board !!!..Looks like a great project !!.......Thank-You again Everyone.........Best Regards..........Eugene52
                    http://www.deepers.com/english/Metal_detector-tests.htm
                      Hi Alexismex
                      Esteban
                      Hi Esteban
                      Not regulator IC, It is reference voltage IC.
                      Best regards.
                        HiAlexismex
                        Best regards.
                        Hi Alexismex
                        Manna and Eugene52 requested from you , please upload some pictures
                        From inside of the box and circuit .
                        Best regards.
                          Hi Alexismex
                          Best regards.
                          I remember your good pictures from inside of MINEORO PDC210.
                            Hi. Please who can tell me about the discri led and potentiometer.
                            As i see the signal is the same who goes at the analog instrument and to the buzzer.
                            So nothing special signal for ferrous objects. BUT i see that the suply of the transistor for audio out, is from a 555 that it triggered from the transmiting pulses. So maybe there is a delay for the ferrous or no ferrous. Can anyone tell me about what is happening exactly on the 4070???
                              Hi.
                              I checked the oscillator and the pulse delay with a simulator and i found that Q7 can't triger the U9. So U9 gives continue pulses for the audio. But WHY Q7 is connected with pin 2,6 of 555. It is as astable but it must connected as monostable.
                              Any help for the error???
                              Does Alexismex can check it??
                                hi Geo i builder one pcb for deepers and work well in manual mode .
                                http://www.4shared.com/file/12487545.../SN850999.html
                                http://www.4shared.com/file/12487617.../SN851002.html
