“S”- tone discriminate metal detector.
  • “S”- tone discriminate metal detector.
    This is my present for CHRYSTMAS. This is “S”- motion metal detector without meter. Work many well with tone discriminate.Work better many professional detectors.Please, save in GEOTECH thread. Without problem in set.
    Schematic here
    http://www.skatafka.com/download.php...d050dd930632ae
    Hi all
    Two tone detector by SASCHO ,
    SASCHO welcome .
      Hi SASCHO
      Please see this link : http://thunting.com/geotech/forums/showthread.php?t=12617&highlight=sascho
      My questions without reply.
      Please ……………..
      Best regards.
        Hi to all
        I cannot download anything from this three link.
        If you had success, please uoloade here .
        Best regards.
          Hi SASCHO
          Why you called it ,“s” motion ?
          Best regards.
            Originally posted by aft_72005 View Post
            Hi SASCHO
            Please ……………..
            Best regards.
            post #51 .
              To aft 72005
              1.minimal
              2.Pin 1 ne5534 and pin 7 -180 grad.
                MISTAKE IN SCHEMATIC-
                R 24k 4,7M
                Sorry for fault.
                  To aft 72005
                  1.minimal
                  Hi SASCHO
                  Yes, you are right. I knowing it which Pin1 of ne5532 and pin 7,
                  had, 180 degree Phase deference . because first 5532 apamp
                  wiring amplifier- Integrator mod and second wiring in inverter mod.
                  My opinion was other thing. This is not my questions, reply .
                  I need know phases difference between receiver amplifier
                  Output and ,ground section and discriminate section chopper
                  When variable disc and ground pots from minimum to maximum.
                  1 – at discriminator chopper section: How much degree phase
                  Differences between pin 1 of ne5532 ic
                  And pin 1, output of lm393 when diskr. Pot variable from minimum
                  to maximum?
                  2 – at ground chopper section: How much degree phase differences
                  Between pin 1 of ne5532 ic and pin 7,
                  Out put of lm393 when ground pot variable from minimum
                  To maximum?
                  I hope, you attentive my opinion .
                  Best regards.
                    Hi to all
                    Best regards.
                    Please present other links. Nothing download from this three
                    Link .
                      Добре си дошъл САШО.
                        Schematic mistake:
                        R24=4.7 M(Megaom)
                        I'm sorry!
                          Hi SASCHO
                          to maximum?
                          To maximum?
                          Best regards.
                          To Bulgarian language
                          Здравейте SASCHO
                          Да, вие сте прав. Аз зная, че който Pin1 на ne5532 и ПИН-7,
                          имаше, 180 градуса, защото първата фаза почтително 5532 apamp
                          окабеляване усилвател-интегратор елегантен и втора окабеляване в inverter МО.
                          Моето мнение е друго. Това не е моята въпроси, отговори
                          Трябва ли фази разликата между приемника усилвател
                          Изходна и земята "и дискриминира точка хеликоптер
                          Когато променлива и подземните води саксии диск от минимални до максимум.
                          1 - най-discriminator хеликоптера раздел: Колко степен фаза
                          Различията между ПИН 1 от ne5532 IC
                          И ПИН-1, производство на lm393 когато diskr. Може променлива от минималните
                          на максимум?
                          2 - в земята хеликоптера раздел: Колко степен фаза разлики
                          Между ПИН 1 от ne5532 IC и ПИН-7,
                          Вън пуснати на lm393 когато земята може да бъде променлива от минималните
                          За максимално?
                          Надявам се, вие внимателни мое мнение
                          С най-добри пожелания.
