False connection , Why connected 47 k resistors between two inputs of opamp !!!!!!!!!!!!!!!!
“S”- tone discriminate metal detector.
Originally posted by aft_72005 View PostFalse connection , Why connected 47 k resistors between two inputs of opamp !!!!!!!!!!!!!!!!
The 47K resistor is actually connected to the 0V rail. It just looks a bit odd in the schematic because it's connected to the inverting terminal, which is also connected to ground. The purpose of the resistor is to reference the input voltage to 0V.
Yes, not regular showing resistor connect between 2 in puts of opamp.
But my opinion was other thing , as my experiment , no need add 47 k resistors .
may by some manipulation on original circuit , finally gave this result "
Add two 47 k resistor " .
I remember at on of metal detector website , saw dissection about sascho
Best vlf detector , there are circuit with very manipulation and said original
Circuit didn’t work correct . also I built sascho original circuit .it worked
Without problem .but circuit with some tips behind it
Hi
I would like to know which program opens .lay files. I would like to make this project, but I'm not sure how to get a hold of the parts lists. I'm assuming the parts list is in the lay file, but can't seem to open it at this time. Is there a free application that opens the .lay files?
Capasitor size
Hi guys,
What is the value of this capacitor? What part number can I use. I had no idea capacitors were adjustable?
It's on Naeem's schematic's file. If the picture doesn't load you can get it here.
I know the capacitor value is found here some here:
If you look carefully at the PCB layout you will see that the unknown capacitor is in parallel with C1. This allows you to insert more capacitance for coil compensation if it's needed. Presumably C1 is there to help achieve the correct initial phase-shift between TX and RX.
