Superscan PI
  • #76
    50cm diameter coil,, and the inductance of 430mh!
    • #77
      What is the problem, not the metal detecting coil ?
      J112 resistor 4k7-6k8 Could this be ?
      • #78
        Hello, have a problem of metal detection to help SuperScan ?
        Merhaba benim süperscanda Metal algılamada problem var bu sorun nerden kaynaklana bilir ?
        • #79
          6k8
          • #80
            SS5
            It is mine SS5 LCD
            • #81
              GOOD MORNING TO ALL.
              this the WORK here has stayed long in the cabinet,So we decided to design net SCHEMATIC and pcb.
              waiting for approval from the forum.
              With many thanks g.s
              • #82
                Good evening again..
                I see that NOBODY has answered so far,I do not understand their REASONS WHY ???
                I think it's a very good schematically want to build.
                it has built Someone this schematic here
                knows the manager or anyone else here if you work in the schematic published by rospi ..
                It really is the authentic DRAFT..
                again is pending approval from the forum..
                Silence is not gold...
                • #83
                  the links are dead in the original post, the poster is suspended, i'd give up, if you really want this detector send eric a pm and ask him to post the proper schematic.
                  the one posted was not even correct.
                  • #84
                    SU, please keep a contact with his girlfriend. if Eric I read is in bad condition his archive has not be burnt.
                    • #85
                      scheme is correct 100 per cent !!!!
                      what I put also data for coil and values components ..
                      • #86
                        THANK YOU orbit I appreciate that it is right.you have information on the coil such as resistance end ma.
                        sinclairuser You can ask you from the eric a better SCHEMATIC and post it here,I'll be grateful to YOU if you do that.
                        kt315 not interested in delta considers the superscan is a city good machine and I will .
                        • #87
                          Where i can find the circuits because i cant see anythink ...
                          • #88
                            Good evening.
                            Who can give me their to TIMING PULSES from superscan.
                            • #89
                              500us pulse width
                              45us 1st and 2nd sample width
                              1st sample delay 60-130us
                              2nd sample delay 1100us
                              ~100 P.P.S
                              • #90
                                You can convert 100 p.p.s for hertz
