Non-metallic detector schematic!
    This comment found;
    "AN PRS 7 does not function well in low moisture content soils"
    Understandable considering the UHF frequencies. Also, will not go very deep (mines are shallow anyway), And I bet if you wanted to work on one, you'd find that the electronics are potted. There were some variations of this design.
    Overtheedge pointed at two very important things about this detector - 1) That it would detect voids (but not deep ones) 2) It was not very ergonomic (It's hard to say much in the army was back then). So technically it would not "detect" plastic, but the space that it was in!
    It was considered unreliable (not being able to handle dry soil). And the army had to move on to other designs. They changed the design again to deal with plastic mines (at a higher percentage rate).
    But I bet the guys that used these were pros, since their life depended on it!
      Originally posted by luciano furtado
      WARNING:
      Virus infected site!
        WARNING:
        I have removed all the posts by luciano furtado as they contain links to a website promoting SPAM.
        Message to luciano - in case you did this unintentionally (and I hope that's the case) I have not placed you on the banned list. Please do not post links to the same site again.
        Also, please try to place your posts in the correct forums and not distribute them randomly across different unrelated threads.
        To everyone else - please report any bad posts using the red triangle in the top right corner of the post, rather than posting in the thread where it could be missed by Admin. Thanks.
          Dear Friend Qiaozhi notice that this site has no viruses and spam as you can see for yourself just one blog and my "personal blog" schemes with electronic and metal detectors
          No way would site with virus, spans etc ... to the forum ok
          My intention in the forum and learn more with friends, so I did the blog to give my contribution to the level of knowledge.
          My blog **********
          Thank you very much.
            Detector
            [ATTACH]Click image for larger version
              hallo Luciano, have you the code for the led's discriminating MD on your blog?
                My blog http://eco-eletro.blogspot.com/
                Luciano,
                When going to you blog my antivirus software block it because of a trojan threat.
                  My blog **********
                  Your blog site is still auto-diverting to a SPAM site! (CPM AD WORLD)
                  It also opens several popups after a few minutes. Please rectify the problem before posting the link again. If you cannot fix the problem, then do not post the link.
                    Dear friend Qiaozhi Guru was already corrected the problem of the site, now the friends already can securely access, any problem please let me know ok.
                    thank you very much
                      Hello friend cordius not understand what code you want, plus the blog and my personal commitment made in the schemes and electronic detectors Anyway love being here at the forum of Geotech learning and passing knowledge with friends ok
                      descupe errors in English
                      the address of my blog = http://eco-eletro.blogspot.com/
                        thank you very much
                        Are you sure?
                        I have tried once again to access your website and it still auto-diverts to the following spam page ->
                        There is some other stuff (not displayed below) if you use Windows and Internet Explorer. But the following was extracted from Firefox running in Ubuntu Linux.
                        At this time I would not recommend anyone to access the site.
                          Hallo Luciano,
                          the programming code of atmega for your discriminate metaldetector with led's in your blog.
                            Unfortunately the codes that the friend did not want to have for the scheme of this detector was sent to me by another friend, put on only the level of knowledge.
                            More will be posting several other schemes in the full blog ok
                              hi cordius ..
                              ı have only asm .code.
                                Originally posted by lonelyWOLF View Post
                                hi cordius ..
                                very thank's, i try to built it.
