BRN Pi-1 DİJİTAL Pİ
Originally posted by marti View PostGuru, yes LCD[ATTACH]24409[/ATTACH]
Link http://www.masterkit.ru/info/magshow.php?num=320
My variant is better. Have adjusting frequency, pulse width, main delay, sample width, sensitivity. Used pic16f88.
http://www.geotech1.com/forums/showt...o&goto=newpost
I think what to write a new program for this detector is not difficultly. But I can make it only for PIC16F8....... .
And I suspect that in this program (Koschej) is provide counter of switch on. Exist new project for Koschej with digital adjusting some parameters.
Originally posted by kt315 View Postyou can take HEX for CLONE-PI and try to desasembler it. there are projects for atmel and pic, I mean the pic one. CLONE schematic is similar to KOSCHEJ.
Project BRN Pi-1.
Can explain purpose of pot 100 k (between R4 and R6) and also divider R10 +R11? It seems that the divider R10+R11 is intended for the control of a voltage of the battery. Pot 100k (between R4 and R6) is for null balance of U1A?
Thank You
Originally posted by Micheal View Post...
Any help in further developing this machine will be very nice
Using of other opportunity (compare mode) for pic16f88 or pic16f887 allows to receive higher accuracy of conversion and sensitivity (without AD conversion).
found the solution (Setup guide), so the detector can be adjusted very sensitiv without any additional instruments
next Task is to improove the lcd Connection, i think there a some conection made without any look in the datasheets
the hd44780 1602 lcd need a resitor for the led backlight and also a trimmer for contrast, with the 1k resistor the lcd is too bright for hidden treasure hunting
http://www.learningaboutelectronics....-a-HD44780-LCD
if anyone is interest i can send pcb for this Project for 10€ within europe
Originally posted by marti View Post[ATTACH]23505[/ATTACH][ATTACH]23505[/ATTACH]Hi all I have made the PI BRN-1 and I have made some changes and has doubled the depth.
I invite you to try these changes and provide feedback.
I experimented with a 18cm diameter coil, I use a coin of 2.5cm and detected to 14cm Then with the changes detected at 30cm
