Originally posted by Gervm
tr metal detector
It`s more liked on usual VLF IB metal detector. With the same success you may use TR coil construction with any detector of this type. I prefer "hear what I`ve transmited". For it several reasons. Power of transmiter may be medium or low but gain of amplifire must be high and the higher the better. Also on low frequency I use signal compensator to reduce leftover signal from TR coil. I don`t see it here so I think - It will be very difficult for this detector to find auto car (large target) at distance 3-4m.
Originally posted by Gervm View PostIt`s more liked on usual VLF IB metal detector. With the same success you may use TR coil construction with any detector of this type. I prefer "hear what I`ve transmited". For it several reasons. Power of transmiter may be medium or low but gain of amplifire must be high and the higher the better. Also on low frequency I use signal compensator to reduce leftover signal from TR coil. I don`t see it here so I think - It will be very difficult for this detector to find auto car (large target) at distance 3-4m.
I also saw similar detector with two operators. It was early russian bomb detector. But now it possible to build simple and cheap device with the same parameters by using opamps. I can draw circuit that designed several years ago but I need time. It was "wet" but worked enough stable.
Originally posted by Gervm View PostI also saw similar detector with two operators. It was early russian bomb detector. But now it possible to build simple and cheap device with the same parameters by using opamps. I can draw circuit that designed several years ago but I need time. It was "wet" but worked enough stable.
