Hi. Thanks for your answer. I'm trying to create the PCB from the scheme in the file sch. Unfortunately it returns me error. Does someone know how to help me?
The error is:
"The schematic file includes netlist errors that should be corrected"
I open ExpressSCH and try to use "checking schematic for netlist errors" and here some component not have pin number.
Someone have all ready create the PCB scheme???
please send me your schematic and i check all.Tomorrow i have free time for this
My email [email protected]
I work many-many years with expesspcb. For me best of all. For pcb i make export pdf file and use corel... mirror etc. For Gerber only factory-expresspcb has this application. Last year i search for software but don't find. Maybe Qiaozhi has solution for us
best regards
Andreas
ExpressPCB does not support Gerber-out on purpose. Otherwise users could simply use the free software to have their boards made by another company.
However ... ... I think I have a solution.
It is possible to print from ExpressPCB to a file in HPGL format. First you need to install an HPGL printer driver. In Windows XP you need to do the following:
Deselect "Automatically detect and install my Plug and Play Printer".
Select Next.
Set "Use the following port:" to "FILE: (Print to File)".
Select Next.
Set "Manufacturer" to "HP".
Set "Printers" to "Hewlett-Packard HP-GL/2 Plotter".
Select Next.
Set "Do you want to use this printer as the default printer?" to "No".
Select "Do not share this printer".
Select Next.
Set "Do you want to print a test page?" to "No".
Select Next.
Select Finish.
Then start ExpressPCB and open your layout. I used one of the supplied examples. Select File > Print, and print the required layers to the Hewlett-Packard HP-GL/2 Plotter you added previously.
Now download "ViewCompanion Pro" from "www.softwarecompanions.com".
Open the previously created HPGL file (with .hgl extension) and view it in ViewCompanion Pro. Then select File > Save As, and save it as Gerber RS-274X.
Voila ... you have a Gerber file from ExpressPCB!!
Hello, can some tell me if this schematics works good, how is it compared to tm800 tm808 tf900?
If it's working good I can make schematics and gerber files for fabrication with Orcad.
