Whites 5000D Coil/Probe/Switch Question
  • Whites 5000D Coil/Probe/Switch Question
    Hi Folks,
    I have a rainy project that involves having dual plugs installed on the Whites 5000D Control . Of corse there's already a factory female plug for the Coil but I have a Discovery Electronic's Probe I also want to install the Probe to the box as well. The probe works well with the 6.59 feq.
    What I need to know is how to correct the two together using a toggle switch to switch between the two.With both being pluged in together on the control box.
    Something so I can have the coil on and probe off then switch the Coil off and probe on.
    I think it would be EZ to do with either a Toggle with "On-Off-On" but have no idea what wires from the circut board effectively would turn
    off the coil with the switch bridged to the probe with the same wires.
    That way hopefully when the toggle is switched to the "right" the coil would be "ON" with the middle position being "OFF" and then to the "left" the probe would be "ON".
    I need to know if this can be done this way or will I need to have two toggles, one for the coil and one for the probe.
    I also need info on the 5 colored wires that go from the bourd to the coil and if I can use them to Bridge to the 5 wire female plug I will install for the Probe.
    Anybody that can help me out email me at < [email protected] > with either some plans or diagrams on how to do it right. Thanks, Woodstock
