Help with building CCO?
    I couldn't find 30 swg wire at the particular electronics store I went to so I got the next closest thing, 26 awg. My calliper measures the diameter at 0.42mm, should I reduce the number of turns in the coils to compensate for the slightly thicker wire or does it really not matter as long as the coils are similar?
      Try to 0.42 mm. Maintain 2 * 50 winding turns.
        EPE "Bounty"
        I am under construction. This circuit can be more deep. And the ratio of CCO, who is the best?
          I am under construction. epe "bounty
            I hope that you will not be cloned?
            If you are searching for deep target, CCO is not the best choice.
              EPE "Bounty" and the CCO. Better or deep.Who are better and more simple circuit it?
                EPE "Bounty" and the CCO. / Who is the best?
                Who is better and more simple circuit it?
                  It depend on how you construct one or other. Bad build - bad results.
                  Try EPE "Bounty hunter".
                    Does any one actually have the modified CCO (the one without the radio) built and working?
                    I did a preliminary test using around 10.5 volts with the coils and earpiece loosely attached to leads from the circuit and all I got was a barely audible hiss at times and some times nothing.
                    I still have to permanently attach everything, clean the flux and bring the pot down to 200k from 250k, but I should be hearing something at this point right?
                      Which schematic do you use? I am building one according schematic posted by maikl here in post #12 and it is working. But you cannot expect from such schematic to go deep in soil (for coins mabe 7 cm in soil max).
                        The schematic in my first post. The one in post #12 is a beat balance detector, not the CCO.
                          Yes, sorry. I never tryed CCO, but you cannot expect better results than with BB.
                            I have made CCO metal detector is the same as in your first post.Works great (good sensitivity),coin from 25mm to detect the distance of 160mm (clear shift in tone at 160mm in a crystal earpiece).IC1 and IC2 I put the new.Other parts and wires were taken out from the old unit(old TV,old radio...).But all the parts are identical as the schematic.Pay attention to the "Crystal Earpiece"(their impedance is 200K-300K).You're certainly putting ordinary headphones from 32 ohms.BB metal detector I was not working (but it is certainly better than the best BFO).The CCO is extremely easy for beginners to do it.If you can not like this simple device to do something more complicated you will not surely (give a master to you to make).
                              CCO is better than BB: has a better detection and is not that important position of the coil(as part of a millimeter at IB metal detector).I would not want anyone to persuade.Make both and you will see.Anyway it is better to do one of these (CCO or BB) than the best BFO.Which is quite complex (there are a lot of parts) for beginners.
                                CCO is better than BB: has a better detection ....
                                Not according author of both:
                                CCO:
                                "With this circuit, I obtained a one-tone shift in an AM radio speaker at 15 cm (6 inches) with a 27mm (1 inch) diameter coin."
                                BB:
                                "If well adjusted, it will pick up an old English penny at 150mm (6”)"
                                The same depth in air. I suppose that author has build both not only one as you.
                                Generaly speaking it is hard to get something from nothing. And one chip detectors are pretty nothing (even 12V supply was used). With mine BB I can easily detect 30mm silver coin at 15cm in air but in soil (in my testing plant) it is hard detectable deeper than 7-8cm.
