  • Excuse me, I did not understand the question.
    Terminal "D" of J113, is connected in pin: 2; 3; 5; 6 of U10, respectively.
    So I have it in my GS4, which is working.
      hello jose ... I think I got confused with the answer there I took a picture so you can see how I understood the last answer ... according to your last answer q5, q6, q7, q8 must be modified pin D ... ERROR IN THE SCHEME DE alex? ... Greetings
      • Yes, it is exactly what you published.
        The image below taken from the original, can clarify the doubts.Click image for larger version
        • thank you very much jose for your clarifications .. in the case of q10 and q9 the pin D If it goes to earth? since by the mentioned thing now I think in q10 and q9 are not correct in the scheme?
          • For the case of Q9 and Q10, the "S" terminal is connected to ground or GND. The attached diagram is correct, although there could be some error.Click image for larger version
            • hanks José I almost finished the plate and with the space to adapt ne5532 and with the 7660 source I will use instead of ne5532 mcp602 feeding positive and negative with 100 oh
              • hello jose, I have a problem, I can not find ca85 .. What substitute can I use for ca85?
                • Originally posted by ricalbertvig View Post
                  Do you mean the OA85 Germanium diodes?
                  Then try NTE109 or 1N34 or 1N270
                  • You can use BAT85, but even regular 1N4148 will work.
                    • I used 1N60, because that is what I was able to achieve.
                      • DEAR ALL MEMBERS. PLEAS SHARE Bernte SMD PCB COMPONENTS IN TOP AND BELOW SIDE AND SEARCH COIL DETAIL.
                        • all in one
                          Bonsoir Jose excuse me for my language;
                          i hope you send me the schematic final for this machine ,with allimentation schematic
                          it's my first experience , thank you
                          • Goldscan is very very tricky to get properly working.
                            I would strongly suggest looking into easier project like Minipulse and Barracuda which do have complete "final schematic​"
                            • Hello, what would be the reason why the regulator 12 volts negative after a while burn, very hot when connecting the coil
                              • I think it should be because I use a very thick wire for the coil .. I get 1oh the wire is thick 18 .. what wire is the ideal? ... Thank you for any information
