Originally posted by reis_43
Originally posted by pito View PostHow can I make this 15mv = check voltages on pins 9 and 10 . How much is changing voltage on pin 10 ?
Look post #369
Originally posted by eduardo1979 View Post
You could try to make a modification, replacing the J112 with a CD4066. The bad thing about all that is that you have to do it with cables and that is not good, because the cables generate noise and right there the noise is of no interest.
is that correct transistor to integrated CD4066 pin drain connected to pin 1 gate to pin 2 and source to pin 13 i want to modify your circuit on GS5-LITE
To see the voltage changes on pin no. 8, the voltage on pin no. 10 must change slightly below or above the voltage on pin no. 9, in your case you won't see this because the voltage on pin no. 10 is lower than 0.06 mV, check the circuit , set pin #10 to -15mV and adjust the voltage to "0V" with a 50k potentiometer, you should observe the voltage change on pin #8.
