ETI561 metal detectors
  • ETI561 metal detectors
    ETI561 I am building a metal detector. I need to PCB. And a 30CM coil data
    For PCB and how to build see ETI561 article again (and again).
    http://www.geotech1.com/pages/metdet/projects/eti561/eti561_150.pdf
    For 30 cm coil you need to wind 46 turns.
      ETI561 and CCO of the ratio. Who is best
        http://www.bcczy.com/bcczy137b.html
          Copy the circuit board using thermal transfer paper
            Who do ETI561
              Who do ETI561
              You ETI561!!!
                I wonder if someone already friends rode ETI561 this detector and how it sencibilidade.
                Thank you very much...
                  ETI561 is the best BFO detector.
                    And the best in terms of that sensitivity??
                    Say that his sensitivity to detect a small metal plate of 2cm x 2cm??
                    Thank you very much yhl
                      ETI561谁建立。灵敏度可以吗?
                        ETI561 who is in the building. Sensitivity can it?
                          thanks for good information friend
                            luciano Furtado do not be mad at yhl he is a bit "strange". My advice is to do CCO metal detector:http://www.geotech1.com/forums/showthread.php?t=16777
                              Thanks friend already took over my conclusions about the scheme, and had ridden other type is much more anyway thanks for your attention...
