Help for Stuart
  • Help for Stuart
    Hello.
    I need help for all documents for Stuart PI metal detector. And if have somme changes in schema .
    Somebody for help.
    Please and TNX.
    BEST 73
    Originally posted by zoran7kk View Post
    Hello.
    Somebody for help.
    Please and TNX.
    BEST 73
    I have a working project, and the documents. What do you need?
    Don
      Thanx dfbowers for ansver.
      I"m make this detector and i dont know why not work.
      I need make new board ...all new.
      I"m see some changes in schema and this confuse me.
      Q from 32 kHz is beautiful solution.
      I have Q-40 kHz but some hobists from espanya ( EA ) make same detector without complementary pair transistorc (? BC PNP-NPN).
      This confuse me .
      I think make tvo detectors .
      Delta pulse and Stuart and compare who is better. HI HI.
      OK.
      Sommething is very big mistery .
      How calculate coil for Stuart? Diameter, wire, number wires, etc.
      I finaly stay with Stuart but in schema have somme bugs.
      I"m find old schema , and sommething new and i try compare changes.
      Then i try make new design board.
      I try with free Eagle program or klasic carbon pencil.
      TNX dfbowers AGAIN.
      If i need sommething i make new post and you know what hapend with project.
      VY TNX
      73 BY BY
        This confuse me .
        OK.
        TNX dfbowers AGAIN.
        VY TNX
        73 BY BY
        I bought the Stuart PI as a kit from Magenta. It made things easier. I also built the Stuart Microcontroller PI which is a good improvement:
        http://www.magenta2000.co.uk/acatalo...onic_Kits.html
        Anyway, coil can be made from 27 turns .71mm wire on a 190mm diameter form. No Faraday shield is needed.
        Don
          VY TNX 4 INFO
          Thanx for info.
          About coil i m think for somme formula or model for calaulation coils.
          OK VY VY TNX
          If i need something i sent mesage.
          I hope for day or two i start vith construction.
          TNX BY BY
