TwoBox Locator Startronic
    Originally posted by Hakan View Post
    Tack Geo and rider.
    It is likely that you misunderstood me or that I expressed myself wrong. I have made watertight coils with size 1.1x0.7 meters. They should be placed 4 meters apart and lowered into the lake. I tested a 15 meter long cables between the electronics and coils and it works fine. Can easily indicate a squaremeter metal of 4 meter in the air. This is good enough for me .... But I have not tested this in the water. When this is finished, I upload a picture of the "monster" on the forum. Will this not work, I consider your proposal with the magnetometer.
    Hakan
    Hi.
    Try to keep the coil inside the water at horizontal position
      Sometimes you have to hide your searching ....
        when the waves goes far succes in air, but not can penetrate the soil this is due to inadecuate armonic frecuence disposition, this should be corrected whit most turns or other wire distinct calibre, i not think be 2 khz may be an error in oscilloscope operation, or inadecuate tx waves tipe, try square or triangular changing waves these, is strange those yours results, or change transistor ics tx tipe
        an example, es necesaria una broca debida para taladrar cada especifico metal, y no es la exitosa potencia obtenida en aire la que penetrara el solido suelo mineralizado, se necesitan bajas revoluciones para agujerar materias duras, en cuanto a penetrar en agua no toda onda penetrara, solo la que no sufra short circuit o imposibilidad en su introduccion, solo es cuestion de encontrar lo ideal y necesario, y eso solo se encuentra en la dura experimentacion y experiencia, the project sems atractive but dreamed soñador, cual es el dos cajas ideal? bueno este debera ser simple como ese, calma mucha calma y tiempo a todo
          Hi Hakan
          I do so the electronic circuit and am interested in where there is mounted instrument.
            Hi WM6
            With Coils in paralell (face to face) 60 meters between coils I can detect the signal. In 90 degree as standard Twobox with distans of 90cm between coils I can detect a car for 2 meters. Hope you can understand this.
            Yes Hakan, now is clear to me.
            Only I cannot undestand purpose of such measurement, if you use two cheap walkie talkies you can detect signal between those two some kilometers apart. But I think this do not mean much if you use both stations as T/R metal detector.
              Hi WM6.
              I use transmitters and receivers face to face in order to tune the resonance. When I have the longest distance that I have resonance in both the sender and receiver.
              Hakan
                Hi Misko.
                Here is the latest rev of the Locator. NOTE. This is NOT fully developed, but it works well. I lay out the schedule on the forum for inspiration and improvement of the members. This audit is speaker, Earphone, LED, 100uA Instruments and a Voltage output.
                Hakan
                  hi WM6
                  I would ask if they told me to my mail. I write on the forum a little troubling. You could built a metal detector, I am interested in your opinion.
                  my mail- [email protected]
                        hi HAKAN
                        I already bought the material for the construction. I was wondering where to place the LED and instrument
                          hi
                          thenk yuo for schematik
                            hi HAKAN
                            I wonder what it means to "toNMEA" and do you have a PCB design.
                              Hi
                              As I said at the beginning of the thread, this is a one-off project to find an airplane in a lake. I do not think I will do some PCBs for this, at least not now.
                              ToMNEA a Voltage output 0 to 9 volts.
                              Hakan
                                Hi detectoman
                                I think this a pretty clear design, I like it, but I don't believe in usefulness of T/R detectors .
