gary Metal Detector
  • gary Metal Detector
    我完成了我的一部分
    Originally posted by yhl View Post
    我完成了我的一部分 I finished my part of the Gary PI MD
    Congratulations yhl.
    Are coin findings on last picture yours, done by Gary PI, or out from local museum?
      Adjust the potentiometer VR1 of the voltage of 1V, the legs 6 IC9 occur.
        Need help
        I do a circuit. But not enough depth detection / 2.5CM coins only 10CM.
        Circuit the total current only 55 mA. If there are problems?
        Points are normal voltage
          即線圈的問題?
            Originally posted by oros27 View Post
            即線圈的問題?
            Possibly.
            yhl - what are the coil details?
              即線圈的問題?
              Approximately 12 inch OD and wound with a 20 1/2 AWG.
              Approximately 26 Turns
              Inductance, Approximately 400 uhy measured at 1 Khz.
              DC Resistance aprox 0.8 ohms.
                Thank you
                There may be / I is a 0.51CM line. Diameter 20CM, 30 laps of the BFO coil
                  That will give you a coil of around 513uH which should be ok.
                  Do you have an oscilloscope?
                    hello
                    I have no oscilloscope. I just want to ask the next / coil does not match the current will become smaller?>
                      Then it is difficult to see what is happening to the RX signal. You might need to adjust the value of the damping resistor.
                        hi
                        But the current of the circuit is the work of only 55 mA. Each voltage is normal. Electronic parts no problem.
                          I want to know
                          I could try to build a coil. I just want to ask why the current only 55 mA under?
                          Q1 IRF740. I used the 6N60 replaced. Parameters of the same
                            LOOK
                            [Help] display IRF840 What could be better than the tube?
                            IRF840 500V 8A 125W NMOS field effect transistor can be substituted with a common 6N60
                              I agree. The quiescent current seems to be on the low side. Maybe the TX pulse width is too small or you need to increase the frequency. I would recheck the component values in the TX driver circuit.
