I would suggest that you either purchase an oscilloscope, or borrow one from a friend. Without it you are essentially thrashing around in the dark. (In other words, it is important for you to look at the various signals in the circuit to understand what is going on.)
Friends need a flat coil, I have 0.51MM enameled wire. Requires an 8-inch data, and a 12-inch data
Flat coil? You mean spiral coil? It depend on many factor, wire diameter, insulation thickness, distance between turns, inner diameter, outer diameter. The best way is to measure target inductance, which are the same as in regular coil.
