please guide me
    THANKS FOR YOUR REPLY.
    CAN YOU SEND ME THE REFERENCE OF THE MOSFET IT'S more powerfull
    THANK YOU
      Originally posted by mehdi View Post
      thanks a lot aft, but i can not see any schematic there!!
      regard
      Ok mehdi , I will send you superscan circuit .
        you have DP... increase strobe impulse to 1000 us. decrease pps to 25 hz or low. change mos-fet on more powerfull one. change battery on more effective one. use 1 meter ramka coil and more. try... you have all for the success...
        As KT315 said , also delta pulse is versatile, my modified delta pulse can detect 1euro
        Coin from 40 cm distance on air . search coil diameter is 40 cm
          0.5 * 0.5?
          Is this Millimeters, Centimeters, Inches or Feet?
          Anything LESS that FEET at 3 to 4 Meters Deep, and your DREAMING.
          chemelec, see post 6 : ( target is 0.5 meter iron sheet and test is in air at all test)
            thank you very much dear aft, the file is in my inbox now.
              Hi KT315 thanks
              can you please explain how i can increase impulse to 1000 us? and what is your recommendation for powerful Mos-Fet?
              thanks in advance
                What Might work for you is a "Magnetic Locator".
                Typically these devices are mainly used to detect "Survey Pins", But they will detect magnetic metals (Iron, Nickel or Cobalt) at quite good depths.
                  Hi chemelec
                  magnetic locator is good but as you say it can detect only magnetic metals, please let me know if it can detect holes and long time ago(more than 2000 years) buried non-magnetic metals(bronze)?
                  thanks in advance
                  mehdi
                    Hi chemelec
                    thanks in advance
                    mehdi
                    Bronze at 3 to 4 meters deep, Is UNLIKELY to DETECT with ANY Detector.
                    And Who would Dig a hole That Deep anyway?
                      Hi
                      ok, i understand, thanks
                        schematic
                        regard
                        http://www.geotech1.com/forums/attac...1&d=1283949003
