Golden Mask Schematic
  • #31
    To Ivconic,
    Hello Ivconic have a smal Q for you perhaps you can help?
    I got the GM3+ and almost got the IGSL working( waiting on friend with scope)
    I like to know if i can do the same trick for 2 tone with IGSL with GM?
    looks to me that the ic have the pinout for it and finding free pins isnt that hard.
    Am i right or totaly wrong?
    Like to hear a 2 tone to determen good or bad metal.
    Hope you can help
    Thanks in advance Tepro
    • #32
      Hi Tepro!
      Is it possible to make some pictures of the board
      for POWER BOX. I am very grateful to you!!
      • #33
        Привет на все
        • #34
          What GM is this?Is it a GM4?Couse 3+ dont have bourns preci pots on pcb.
          Btw asap will take a pic of the power box/ small board.
          Can some one point me out if theres a chance that this can be a two toner with minor ajustment,say like IGSL from diode to free pins from ic.If so please explaine.My ics are sanded also and my guess is all pcb is the same for gm1/4
          Tnx in advance
          Regarts
          Tepro
          • #35
            Tnx in advance
            Regarts
            Tepro
            GM4
            • #36
              hello
              is anyone able do to make a layout file from that board with conventionel parts (not smd)
              i search some projects for 2012
              regards bernd
              • #37
                the first detector that is sold by Vladimir Lilova the bandido, or tgsl ,golden mask was the initial version of the magnum with two channels ,2 golden mask and golden mask and golden mask 3+ ,the same machine the difference between golden and golden 2 3 is a table golden3 VCO and two-tone discriminationa golden mask 3 + is crafted with special oscillator with two MOSFETs, and in 7555 used the generator which gives two to three times the force tx osciltoru, but Golden Mask 3 .
                Yes! Bandito II (GM2), GM1, GM3, GM4 ... from Bulgaria are simple 2ch. Magnum (Rx,Disk,Supply..) and Fisher 1235 (audio output). Have nothing difficult to make from everyone.
                • #38
                  Is any body have a pics of Golden mask 4 PCB with good resolution?
                  • #39
                    Golden Mask is good only for clean places. In places with old ceramic, dies and finds nothing. See for yourself: http://www.youtube.com/watch?v=rr4MQSTDEqM
                    • #40
                      lol wouldnt be any good over here then
                      • #41
                        maybe you are right
                        but with a layout file and a good shematic it would be easier for the non electro scientists here i am hot for try it but im not able to produce 2ch magnum plus fisher audio layout for a pcb
                        • #42
                          Sure: http://www.youtube.com/watch?v=yiTUIjpRG-E
                          • #43
                            [IMG]jpg[/IMG]
                            • #44
                              Originally posted by iavor View Post
                              [IMG]jpg[/IMG]
                              This is not the way to post an image in the Geotech forums.
                              You need to click on the Manage Attachments button.
                              • #45
                                [IMG]jpg[/IMG]
                                try another tags
                                <img src=http://... .jpg/>
