PIM-2 Digital Metal Detector Project
  • Hi, is the Demo hex v5 compatible with the new v6 PCB? Or do we have to wait for v7?
    • I installed a PIM-2, has no test successful
      • 发布时间 PIM-2的HEX 文件 是一个示范,对于 DIY的 朋友是 没有意义的,即使你 做的, 效果也不 好, 低 灵敏度, 是 单片机控制的,除非你 买他的 工具包 和 PCB 电路板, 或者你 失败
        • Originally posted by liudengyuan View Post
          Please read the forum rules and make your posts in English.
          • Published PIM-2 HEX file is a demonstration for DIY friends is pointless, even if you do, the effect is not good, low sensitivity, is microprocessor controlled, unless you buy his kit and PCB circuit board or you fail
            • Hi every one . I need your help. i build PIM-2, schematics V3 and hex V05. Coil is 20 cm; 4 turns cat 5
              every thing is normal but when i connect the coil the lcd will gone and when i diconnect the coil the lcd will come back !!!
              what is the problem? please help me
              Regards!
              • hello, any body there!??
                • hi every one make and test it?
                  and have complete version to put here.
                  • I managed to disable the demo counter of v5 hex file.If someone need it just ask for it.
                    • PIM-2 very good
                      I really interested in hex for the PIM-2, I'm about to do just some pieces missing me ...
                      but if you stay with it I understood full well the hex.
                      if I would you could spend much help, my email is:
                      [email protected] or [email protected].
                      sorry for my bad handwriting but use google translator.: D
                      • Please send me the file hex.
                        [email protected]
                        thx.
                        Jose
                        • Sorry for the late response.
                          The hex file is in your email inbox.
                          • The only change to the file is that i replaced the command that reduce the demo counter, with NOP command,
                            so the counter will always stay to 500
                            and the first message to show the word "version" in english.
                            • Originally posted by mrtronik View Post
                              Please send me the hex file.
                              [email protected]
                              Thanx
                                Thanks John.
                                Just one more question.
                                As is the operation of PIM2 ?.
                                It is stable.
                                It is sensitive.
                                It is comparable to Delta Pulse.
                                Thanks for your time.
                                Greetings from Argentina.
                                Jose
