PIM-2 Digital Metal Detector Project
  • Originally posted by mrtronik View Post
    The only change to the file is that i replaced the command that reduce the demo counter, with NOP command,
    so the counter will always stay to 500
    and the first message to show the word "version" in english.
    Pls. send me too my email: RamielSaromines@yahoo.com
    • Originally posted by Jose View Post
      Thanks John.
      Just one more question.
      As is the operation of PIM2 ?.
      It is stable.
      It is sensitive.
      It is comparable to Delta Pulse.
      Thanks for your time.
      Greetings from Argentina.
      Jose
      Hello Jose.
      I am sorry i can't answer your questions as i didn't build this detector yet.
      I am very busy ,but i hope to build it some time soon.
      Before you ask how i know that the hex file works and how i managed to disable the demo counter,
      the answer is "Proteus VSM Simulation".
      I have very good knowledge of microcontrollers and it was very easy to find the command that
      reduced the counter and disable it by replacing with NOP command.
      I also changed the turkish word "version" in the first screen message with the english word,
      as this was very easy.
      So, i can only guarantee that my hex file function is 100% exactly the same with the original
      hex file PIM-2 v5 Demo except the two changes i talked about.
        Hello Jose.
        Thank you very much John.
        Construction will try in the coming days, after getting all materials.
        I'm a little slow, when finished PIM-2, will share the results in the forum.
        A Cordial greetings
        Jose
        • OK Jose.
          It will be very useful for me and the others if you share your results of testing this detector.
          Thank you.
          • Hi mrtronik
            Please check your email inbox.
            Thanks.
            Speedy_G
            • hello,
              can somebody post latest pbd files (maybe sprintlayout or gerber) here
              and also cracked hex file (zip Container as Attachement)
              who of geotech members within europe can burn atmega with updated code ?
                hello,
                Hey man.
                You can find all documents and updated files
                http://www.lugatek.com/forum/index.php/board,15.0.html
                • i searched the thread there i am also registered user, but can´t find the hacked hex files without Counter
                  do you know if vers5 hex will work with vers6 PCB from Mustafa?
                    OK Im going to ask to him bro, just let me sometime
                      hello,
                      Hello Berte I can't send you reply on your PM it say's you're inbox is full..or exceeded.
                      • Originally posted by Saromines Ramiel View Post
                        hi my friend .if have it send me.
                        • PIM2
                          anyone know the right steps to make a coil for PIM2, either CAT5 or another.
                          I made a coil with cat5 but has 3.4 Ohm, I guess I was wrong about something ...
                          so if anyone can help me to complete this project, then I'll upload some images.
                          thanks in advance.
                          sorry for my English.
                          • Originally posted by mohandes View Post
                            Ok my friend..
                            • hello mohandes, did you gt the link from ramiel?
                              @sabios
                              try yv wire 0,5mm , Diameter 35cm, 22 turns (around 470µh)
                              wire-dia from cat cable is a bit small i think
                              i work on pim2 v06 Mustafa i hope it will work with v05 hexfiles
                              if not i will look for some Controllers from lugatek to buy them
                              • Could you tell me if the PIM2 version 6 of M-usta-fa I did okay but I mention a couple of things, I realize it takes a lot powered on for 1-3 minutes did not know if this alright?
                                else and tried to make a coil with cable juice deflection of a TV but having nothing to view this inductance is a bit complicated.
                                as soon as I have finished I'll post some pictures.
                                by desert is the HEX 05 v supposedly is full, I guess it has some bugs.
                                for a coil with a juice cable TV deflection few laps we're talking I'm doing one with about 18 laps and a diameter of 60 cm not know if I'm good ..
