PIM-2 Digital Metal Detector Project
    Interesting video
    if you place the coil on the bare ground , and you wave the coin above the coil
    what distance will it detect the coin ?
      today I have finished PIM-2. Is the HEX-file a demo version? I am missing the menu parameter TRESHOLD and there is no function of the fading curve. After every restart the display shows:
      LAST 500 USAGE
      LAST 499 USAGE
      LAST 498 USAGE
      and so on. What happens at zero?
      Btw I dont speek turkish.
      Jürgen
        Hi
        Yes, the hex file is a demo version. But there is no function limited. Treshold shows with E or T symbol on main screen. You can adjust with up and down buttons on main screen.
        I am waiting for your problems here.
          LAST 500 USAGE
          LAST 499 USAGE
          LAST 498 USAGE
          Jürgen
          I believe it means that you will need to reprogram the microcontroller after 500 uses. Hence I assume this is demo code.
            Originally posted by elbombaci View Post
            Hi
            Hi elbombaci
            At first, I saw from TV about earthquake in Turkish country , and many people
            Died and many as weather cold having problem. I am sadly in the matter .
            God bless died people .
            My question now, what difference between demo and main software ??
            Best regards.
              Hi aft_72005, and thank you very much.
              Qiaozhi is right. There is any difference between demo and main software.
                Hi elbombaci, and thanks...
                please tell us about PIM-2 [digital version of Delta Pulse] performance ?
                PIM-2 is better in depth detection or analog Delta Pulse ???
                with best regards...
                  Does lugatek.com sell the pcb ?
                    Hi GOLDENSKULL
                    As I didn't build PIM-2 , I cannot saying about elbombaci , Pim-2 circuit .
                    But my opinion in general form , as we can tune exactly some part of analog
                    PI circuit , you can obtain more dip in the matter .
                    My delta pulse detect 1 coin from 40 cm on air . coil diameter is 40 cm.
                    Delta pulse working stable on the ground. But If tune it correct!!!
                    Also interesting PIM-2 , but couldn't fined free time to build it yet .
                    I hope Turkish people produced report from PIM-2 real test on ground here.
                    As study PIM-2 circuit , think also as analog delta pulse , working good.
                    Best regards.
                      elbombaci , Thank you
                        Hi GOLDENSKULL,
                        There is any performence difference between Analog Delta Pulse and PIM-2 Digital Delta Pulse.
                        Yes, lugatek.com sells the pcb. You contact me.
                        [email protected]
                        You watch PIM-2 videos to see performence of PIM-2 on youtube my channel.
                        http://www.youtube.com/user/elbombaci
                        Updated schematic from v01 to v02. (R3 from 15K to 22K, R4 from 10K to 12K)
                        Updated software from v03 to v04.
                        I am sorry for my bad English
                          What is the rotary / push-button switch you are using?
                            Hi GOLDENSKULL,
                            [email protected]
                            Hi elbombaci
                            Please upload here .thank you .
                              Qiaozhi
                              It is for my LPG level indicator project. I used to an easy use.
                              aft_72005
                              I attached V04 documents here.
                                Qiaozhi
                                aft_72005
                                Thank you , elbombaci
