PIM-2 Digital Metal Detector Project
  • first i can say theat Setup procedure of coil from felezjoo is more complicate as i see and as i read
    at pim2 you can hook up a pi coil that lays around and the System start equal what values
    • I send email to lugatek but there is no reply yet until now.
      • ok yesterday i tested my felezjo pi, and it seems a bit better than pim2
        (disc, tone mode, hale menu for Setup)
        but i have no idea what detector performs better in real ground and for most depth in ground with big Frame 1m*1m
        i have no time for field testing
        but both seems very powerful and deep
        i wish we could Import both Projects to pic Controller System and made it free for all without Limitation
        felezjo is demo Version but Counter is disabled (ok i know thats no in sense of author- but it is senseless if you have to reprogram after 300 times)
        • Felezjoo has good penetration deep of a large coil...my problem with this unit is the stability on high meniralized soil much more on 1 meter
          coil..
          • hi My friends
            Is there a difference between Atmega 8 and atmega 8-16?
            and thank you
            • Originally posted by BlackDevil View Post
              Hi Jap! I need your help.This is my PIM-2, schematics V3 and hex V05. Coil is 38 cm; 24 turns cat 5 - 2,75 ohm, 0,660 mH, CPU Atmega8-16PU.Very low sensitivity! 1 € - < 10 cm! No discrimination. What the problem?
              Regards!
              [ATTACH]24468[/ATTACH]
              There is no sensitivity in the device
              What does this thread mean in the pink circle
              • Can I have a working firmware ? with sound ?
                • This topic seems stuck from looking at previous pages
                  • Did you collect Pim2?
                    • as i remember PIM1 was open one... but PIM2 i sure doubt. find up videos of this guy in youtube and ask him there.
                      a way MET_DET\Delta Pulse Sniffer XR-71\turkish_PCB\LCD\lcd dp all files.rar"
                      for example https://www.youtube.com/watch?v=mTfxXjqmLII
                      Teknoloji Ekibi
                      5.87K subscribers
                      Arkadaşlar yeni kullanıcılar i?in Delta Pulse 3s Plus kullanımını ve men?y? anlatmaya ?alıştım. Umarım faydalı olur.
                      Bize ulaşmak isteyenler i?in iletişim numaramız: 0216 379 2 379
                      • before they wer selling microproccessor but now I think not.
                        • I have a problem with the Lugatek PIM-2 V-06:
                          After switching on,the signal sound.The LCD shows the hit,but there is no sound.
                          What could my problem ?
                          • i have working pim-2 mustafa layout
                            i can sell pre programmed controllers
                            it is very powerful, look my earlier posting in this thread
                            • Hi the problem for pim-2 is ( not deeper ) but stable on ground
                              • Thank You for the offer,but there is no problem with the program if the downloaded hex is good.
