PIM-2 Digital Metal Detector Project
  • Originally posted by hamma View Post
    sometimes goes crazy or sometimes return to the usual noise without detect.
    Hi hamma
    When you say sometimes the mistake in a bad welding or bad connection in pcb,, please re welding to some points and check copper on the links of the pcb.
    best time
    j.
    • I worked in this direction, it is OK, sounds now become crazy all the time, I found that v_signial voltage is not stable at "atmega/23", so i followed the wrong signial on "D3 / 1,2, 3 "up to R41 and T8. I stop because I slam my VD7.
      I changed the diode and back to work some time, after that the atmega is dead, and I test 5v on D1, sometimes it reaches 8v, which due grilled atmega.
      I decided to replace d1, 2 c3, 2,5,6. it will suffice you think?
      I'm waiting on Monday for the shops.
      In my country the weekend lasts two and a half days
      I eager to resume
      thank you still, good Sunday
        Hi hamma
        -OK
        -re programming D2 IF not ,replace it.
        best time
        j.
        • Hi Jap
          I made ​​the project ( PIM-2 ) again, I use ATMEGA8A-PU
          But I have not got a good result
          So the question is : if I can use this ATMEGA8A-PU, and must I use ATMEGA8-16PI ?
          thanks
          • Originally posted by volcano View Post
            Hi volcano
            --good for succeede for programming Atmega8.
            -Any Atmega8-xxx worked.
            -good result---> come from good coil,good pcb,good work.
            -what the results?
            best time
            j.
            • thank you Jap
              I have made very good PCB and I test all components ( voltage ok)
              look, I said that I have Atmega8A PU, not Atmega8 there is the A at the last
              Another thing,in the two PCB I have a Dropout ( the display chow 10 vdc only ) and when I measure it with multimeter I get it 10 vdc
                thank you Jap
                Hi volcano
                -Atmega8A PU,,,I test it & work,,[A mean NEW].
                -For Vbat change the values R3 from 15K to 22K, R4 from 10K to 12K.
                best time
                j.
                • thank you Jap
                  but I use R3=22k and R4=12k as you say
                    thank you Jap
                    Hi volcano
                    -See c55=1uf
                    best time
                    j.Click image for larger version
                    • hi Jap
                      can you sell to me PIM-2
                      because I have made two projects, but I do not get a good result
                      I am more worried
                        hi Jap
                        I am more worried
                        Hi volcano
                        -I'm sorry,you Order & asking at the source.
                        -Put a clear picture of the top and bottom.
                        best time
                        j.
                        • Originally posted by jap View Post
                          Hi volcano
                          best time
                          j.
                          ok Jap
                          I will put the pictures tomorrow
                          • Hi Jap
                            what is the value of Vbat
                            I find it 4 V
                            • Hi volcano
                              Vbat=4.2v
                              best time
                              j.
                                Hi volcano
                                Vbat=4.2v
                                best time
                                j.
                                thank you Jap
                                I find it 4.1v
                                So my PCB is good
