PIM-2 Digital Metal Detector Project
  • Originally posted by jap View Post
    Hi Ropcsika
    -Read reply #197
    -for stable R5=680/2~3W
    - for sound test T2,R8,R9.
    best time
    j.
    Thanx jap
    Work perfectly, it was a soldering error.
    • Hi Jap! PIM 2 v.05 E=12V; Vbat=4,2V (R3=22K,R4=12K). If E=15,6 v (12x1,3V NiMH) ... Vbat=? (R3=?,R4=?).
      • Originally posted by BlackDevil View Post
        Hi BlackDevil
        -See!
        best time
        j.Click image for larger version
        • Buna Jap ! tu est Stefan asa ? am ku voi ceva sa terminam daka avec interesur jeu vorbesk ka voi ama nu pot bas sa skriu bine am vazut ka santec mult bun programer da trimetecam skipu adres sa vorbim . Salut Jap !!!!!! Greeting !!
          • Thank you very much, jap!
              Please write in English ->
              http://www.geotech1.com/forums/showt...-of-the-Forums
              • greeting jap !I speak your language and understand but I do not know to write not really send me your contact thank you !!ok Qiaozhi !!!!!! It is a translation ! jap but you do not have!
                  jap not Romanian... I think he's an Egyptian.
                  • ahaa sorry ,I do not understand why Now I understand ! _regards Maikl !!
                    • Need Help!
                      I have finished PIM-2 using Schematics V3 and hex V05. Coil is 35cm, 24 turns cat 5e, 2.8ohm
                      CPU Atmega8-16PU.
                      LCD shows something like I2 or 12 after S1 and S2.
                      • SOMEBODY can tell me the meaning of s1 and s2 on lcd ????
                        thank you to all
                        • Hi Jap! I need your help.This is my PIM-2, schematics V3 and hex V05. Coil is 38 cm; 24 turns cat 5 - 2,75 ohm, 0,660 mH, CPU Atmega8-16PU.Very low sensitivity! 1 - < 10 cm! No discrimination. What the problem?
                          Regards!
                          My PIM-2.rar
                          • elbombaci,
                            please answer to last 3 replies, we need your help.
                            • Originally posted by darkobx View Post
                              elbombaci,
                              "elbombaci" web site
                              http://www.lugatek.com/forum/index.php?topic=150.0
                                Regards!
                                [ATTACH]24468[/ATTACH]
                                Hi BlackDevil
                                I was admiring your work on the PIM-2 detector and its very professional-looking. Congratulations.
                                Did you ever solve the small problem you had with the LCD display which you posted previously e.g. 'LCD shows something like I2 or 12 after S1 and S2?'
                                I am thinking of building the PIM-2 as the digital version of the Delta Pulse 2+ which I built successfully only last year with discrimination employing the PIC 18F252 microcontroller.
                                Good luck with the rest of the project...oh, by the way, please check your Personal Messages Inbox.
                                Ciao
                                Speedy_G
