I saw you tube of the surf pi.
I think we could freshen up the time to sense a target modding this area of the cct..
time shifted samples are judged on their amplitude, the thing is, the differential amp has large time constant caps on it so you have to do loads of samples to charge the caps - in order for it to give a big enough difference to det a target.
If each sample gate was a sample and hold you would not have to wait to take loads of sample to det the target.
If you use 2 of the attached Sample and hold ccts into a Diff amp - this would speed up the time to recognise a target
