Make sure the LM358 is not installed backwards.
edit: Never mind the 358 orientation, but look at this:
If you have +5V at NE5534 pin-7, you should also see +5V at LM358 pin-8. They're supposed to be connected.
You must be able to measure very low resistance between those two pins, if not then you may have an open trace or bad solder.
Oh, yes I rounded 4.97 up to a 5 (I like things simple).
