I had a Similar circuit but using a 78L05 and 79L05 and this diode on the Positive supply stops this problem.
Was Originally seen in a TI Application Note.
I think I understand the anode of the diode to pin 1 of icl7660 and the cathode to - of capacitor C13. Is this correct?
In the diagram I see that the capacitor closest to pin 1 of the 7660 is not C13 but C15
Can you tell me the correct connection?
The problem was solved with the modification that was published, now it is working
Now what I do not get is the sensitivity, the NE5534 that I have are from Texas and with all of them equal
I have ordered in the local trade of another brand, will arrive in a few days
I read that you can also increase the sensitivity by changing the coil's damping resistance, I'll have to try
I'm not sure whether to increase or decrease the ohms of the resistance
I've seeing single side boards here, but due to the many posts i cant find the one. Can someone refer me to single sided pcb for the Surf PI Pro which is confirmed working/accurate? Here the only one i find: http://www.geotech1.com/forums/attac...8&d=1450647729
Tacoma who is a member here sells them on ebay. That's where i got mine from. Mine works fine but i have seen other with problems here on the forum .
