I have made PCB designed by ApBerg and it was not working ... no sound at all
Changed NE555 to TS555 still same.
Only if I touch IRF9640 I get some sound in headphones ..
I get huming sound when I touch volume pot - connected to darlington transistor
or when I touch both IRF and that pot pin I get sound like I shoul'd have if found metal
from youtube test videos...
R2 trim pot is now 3.3k resistor
Voltages
TS555 pin 4 and 8 is 12.10V
IRF9640 S leg has 12.1V
7660 has -4.36V on pin 5
7660 has 5V on pin 7 (and 8 ?)
4093 has 5V on pins 1, 9, 12, 5, 14
4093 has -4,35V on pin 7
4066 has 5V on pin 14
4066 has -4,35V on pin 6, 8, 9 unused part
4066 has -4,35V on pin 7
358 has 5V on pin 8
358 has -4.35V on pin 4
I am using 0,4 mm enamelled copper wire 23 turns - 22 cm diameter 2.8 Ohm at PCB and 2.3 Ohm at coil
Don't have inductometer...
Don't have oscilloscope... yet
Voltages
358 has 5V on pin 8
