Surf PI Pro
  • Originally posted by sdesic View Post
    Regarding No4 ... I have found that Coil calculator is not bad solution but in real life it can be wrong.
    http://www.geotech1.com/forums/attac...7&d=1290969584
    Used 0.4 mm copper enameled wire (that is 0.44 with layers of isolation)
    in coil which is 23 cm and 24 turns.... calculator says more than measured.
    coil calculator ... 0.93 mH
    Try entering the correct value for the radius of 115mm, and not 230mm, which is the diameter.
    For a radius of 115mm and 24 turns, the inductance is calculated as 417uH.
    • My fault
      did not read ... I assumed it was diameter
      417uH is still a bit more than required....
      is it mH (miliHenry) or microH
      than we got hacked ... by Mr.501
        My fault
        The result is shown in mH. Therefore 0.417mH means 417uH.
        If your trying to get to 300uH, then try either 20 or 21 turns.
        The hacker first gained access on September 11th (911) and launched the attack on the 12th. Today is Friday the 13th.
        • seems that iam going to use coil wit diameter 250mm, 0.4 thickness, 13 turns
          my question is how to know the required or best uH needed ??
          • you need to be in 250-350uF range so you need more turns
            18-21 turns...
            it is best to try with 21 and than measure depth you get with that coil and remove turn or two and measure again
            • iam having some problems if any one could help me please
              1- R36 is "12 Ohm" can i replace it with 10 Ohm 1W resistor
              2- C7 which is 1uf can i replace it with electrolyte one it has + and - , if no i have another one 1uf ceramics but 250v large size is it ok ?
              3- for R20 & R18 which are 47K can i replace one of them with 22K and the other is 47k but 1/8 W is it ok ??
              4- the capacitor i used is small as shown in fig so i think its low power is it ok or shall i change them ??
              please i need fast answers i must finish this detector as soon as possible
              thanks in advance
              Mohamed Ghitas
              • 1. Yes, that's fine.
                2. Electrolyte will probably work OK. 250v ceramic will also work.
                3. 1/8W is fine. I would put the 22k in R20, probably will make the threshold a little sensitive but should work.
                4. Caps should be fine.
                • thank you very much Carl-NC its very nice to reply me ^_^
                  i have made the circuit but it didn't work :\
                  so could you please tell me where the points to check with multimeter to know if the circuit is working or not ??
                  thanks in advance
                  • not working
                    my Readings is
                    7660
                    pin 1 :1.75 v
                    pin 2: 2.43
                    pin 3:0
                    pin 4:-2.29
                    pin 5 :-4.59
                    pin 6 :0.75
                    pin 7:5.02
                    pin8 : 4.97
                    4093
                    pins 11,3,4 all -4,37V
                    pin 10 :4.67
                    4066 has 5V on pin 14
                    4066 has -4,59V on pin 6, 8, 9 unused part
                    4066 has -4,59V on pin 7
                    and when i measure pin 11it gives small beeb
                    358 has -3.92V on pin 8
                    358 has -4.95V on pin 4
                    NE5534
                    pin 1 :3 v
                    pin 2: 0
                    pin 3:0.01
                    pin 4:-4.59
                    pin 5 :-0.43
                    pin 6 :0.14 "can control by offset"
                    pin 7:4.97
                    pin8 : 2.91
                    NE555
                    pin 1 :0 v
                    pin 2: 6.25
                    pin 3:10.49
                    pin 4:12.12
                    pin 5 :8.09
                    pin 6 :6.24
                    pin 7:6.23
                    pin8 : 12.07
                    i replaced delay 10k pot with 50k pot
                    and placed 200 Ohm on the 3906 emitter
                    iam using coil with diameter 125mm ,0.4 ,19 turn
                    here is my circuit
                    thanks in advance
                    • i don't have any sound until i touch the mpsa13 base with the multimeter and the sound increase when i touch the mosfet in same time with my hand
                      but there is something strange happens now i unplugged the power and trying to measure the points i found that the GND and +5, +12 all are short circutied with GND
                      555 all pins are connected to the GND except pin 2,6,7
                      76605 pins 3,5,7,8 also connected to GND
                      is this is normal ??
                      the pots gives no response only the volume and offset they made some changes in sound and in pin 6 of NE5534
                      • did you check orientation of your NE555 ?
                        you need to pop out all ICs except 7660 and try voltages and then with NE555 same thing
                        can you try measuring without coil also and before you pop them out (ICs)
                        • okay i removed the coil and measuring the ics now
                          • my Readings without coil
                            7660
                            pin 1 :1.75 v
                            pin 2: 2.43
                            pin 3:0
                            pin 4:-2.29
                            pin 5 :-4.59
                            pin 6 :0.75
                            pin 7:5.02
                            pin8 : 4.97
                            4093
                            pin 10 :4.67
                            and when i measure pin 11it gives beeb
                            NE5534
                            pin 1 :3 v
                            pin 2: 0
                            pin 3:0.01
                            pin 4:-4.62
                            pin 5 :-0.51
                            pin 6 :0.06 "can control by offset"
                            pin 7:4.97
                            pin8 : 2.91
                            NE555
                            pin 1 :0 v
                            pin 2: 6.35
                            pin 3:10.69
                            pin 4:12.34
                            pin 5 :8.23
                            pin 6 :6.35
                            pin 7:6.35
                            pin8 : 12.32
                            Last edited by Mohamed Ghitas; 09-17-2013, 04:13 PM. Reason: the multimeter correction
                            • i removed all ics except 7660 and nothing happens shall i measure the pins now ??
                              if yes which pin shall i measure ??
                              • look for GND connection that you mentioned before
                                try to power up and measure voltages on IC sockets -5V and +12V
