hi,
this is my first post in this great forum, and after reading a lot about different metal detectors here, i decided to start building Surf pi metal detector and precisely the surf XX posted by ApBerg AND made by Paku, who provided a very good image of his board.
Now i am waiting for my components to arrive so i can start etching my PCB and solder components, meanwhile i want to share with you my component list based on the board provided by Paku (i added values of each component on the board).
i hope this is going to work so everyone could make his own MD :
*********************CAPACITORS******************* *****************
C1 22nF 0.022uF 100V 5% Mylar Film Capacitors
C2 2200uF 50V 105C Radial Electrolytic Capacitor 16x32mm
OR 1000uF 50V 105C Radial Electrolytic Capacitor 13x26mm
C3 100nF 0.1uF 100V 5% Mylar Film Capacitors
C4 100nF 0.1uF 100V 5% Mylar Film Capacitors
C5 220nF 0.22uF 100V 5% Mylar Film Capacitors
C6 220nF 0.22uF 100V 5% Mylar Film Capacitors
C7 1uF 100V 5% Polyester Film Box Type Capacitor
C8 47nF 0.047uF 100V 5% Mylar Film Capacitors
C9 1nF 0.001uF 100V 5% Mylar Film Capacitors
C10 1nF 0.001uF 100V 5% Mylar Film Capacitors
C11 1nF 0.001uF 100V 5% Mylar Film Capacitors
C12 1nF 0.001uF 100V 5% Mylar Film Capacitors
C13 220uF 50V 105C Radial Electrolytic Capacitor 10x13mm
C14 220uF 50V 105C Radial Electrolytic Capacitor 10x13mm
C15 220uF 50V 105C Radial Electrolytic Capacitor 10x13mm
C? 220uF 50V 105C Radial Electrolytic Capacitor 10x13mm
C16 100nF 0.1uF 100V 5% Mylar Film Capacitors
C17 220pF 50V Ceramic Disc Capacitor
C19 100pF 50V Ceramic Disc Capacitor
C20? 100nF 0.1uF 100V 5% Mylar Film Capacitors
C? 100nF 0.1uF 100V 5% Mylar Film Capacitors
*********************IC's************************* *******************
IC1 TLC555
IC2 NE5534 IC 5534 Low-Noise Operational Amplifier IC
IC3 LM358N LM358 358 Low Power Dual Op-Amp IC
IC4 CD4093 4093 IC CMOS NAND SCHMITT TRIGGER
IC5 L78L05ACZ L78L05 78L05 +5 VOLTS 100mA Voltage Regulator IC
IC6 ICL7660CPAZ ICL7660 CMOS Voltage Converter IC
IC7 CD4066 4066 IC CMOS QUAD BILATERAL SWITCH
*********************DIODS************************ ******************
D1 1N4148 Switching Signal Diode
D6 1N4001 Diode 1A 50V
*********************TRANSISTORS****************** *****************
T1 2N3906 PNP General Purpose Transistor
T2 IRF9640 Power MOSFET P-Channel 11A 200V
T6 BC517 Transistor NPN 30V 0.5A TO-92 BC517-AT/P
*********************POTS & TRIMPOTS********************************
DELAY 10K OHM Linear Taper Potentiometer
TRESH 10K OHM Linear Taper Potentiometer
VOLUME R33 1K OHM Linear Taper Potentiometer
SENS 100K OHM Linear Taper Potentiometer
20K OHM OHM Trimpot Variable Resistor 6mm
100K OHM TRIMMER POTENTIOMETER CERMET 25 TURNS 3296W
5K OHM TRIMMER POTENTIOMETER CERMET 25 TURNS 3296W
*********************RESISTORS******************** ******************
R1 100K OHM 1/4W 5% Carbon Film Resistor
R2 3.9K OHM 1/4W 5% Carbon Film Resistor
R3 1K OHM 1/4W 5% Carbon Film Resistor
R4 100 OHM 1/4W 5% Carbon Film Resistor
R4bis 2.2K OHM 1/4W 5% Carbon Film Resistor
R5 100 OHM 1/4W 5% Carbon Film Resistor
R6 i couldnt find 360 OHM 2W SO I WILL USE 1K OHM TRIMMER POTENTIOMETER temporarily OR
750 & 680 OHM 1W 5% Carbon Film Resistor in parallel to get 356 OHM 2W ( almost 360 OHM)
R7 1K OHM 1/4W 5% Carbon Film Resistor
R8 1K OHM 1/4W 5% Carbon Film Resistor
R9 1.2M OHM 1/4W 5% Carbon Film Resistor
R11 22K OHM 1/4W 5% Carbon Film Resistor
R12 10K OHM 1/4W 5% Carbon Film Resistor
R? 12 OHM 1W 5% Carbon Film Resistor ( i only have a 1/4 W and i don't know if its going to work)
R13 1K OHM 1/4W 5% Carbon Film Resistor
R14 1K OHM 1/4W 5% Carbon Film Resistor
R15 330K OHM 1/4W 5% Carbon Film Resistor
R16 330K OHM 1/4W 5% Carbon Film Resistor
R18 47K OHM 1/4W 5% Carbon Film Resistor
R20 22K OHM 1/4W 5% Carbon Film Resistor
R21 1K OHM 1/4W 5% Carbon Film Resistor
R22 220K OHM 1/4W 5% Carbon Film Resistor
R23 22K OHM 1/4W 5% Carbon Film Resistor
R26 51K OHM 1/4W 5% Carbon Film Resistor
R28 240K OHM 1/4W 5% Carbon Film Resistor
R29 51K OHM 1/4W 5% Carbon Film Resistor
R34 22 OHM 1/4W 5% Carbon Film Resistor
R35 100K OHM 1/4W 5% Carbon Film Resistor
*********************IC Socket Adaptor********************************
4x8 pin DIP IC Socket Adaptor Solder Type
2x14 pin DIP IC Socket Adaptor Solder Type
PS: please correct me if i made any mistake.
IC1 TLC555
