below is a quick setup guide, there are some misunderstandings as I saw from your messages
so I put this guide to correct most of you before you complete the device
it is mostly compatible with the original setup guide except first 3 chapter.
1- 4094 need to be TTL, 5V, 74hc series
- 4051 need to be CMOS, 12V, hc series
- GLCD can be WinStar 12864B, you can connect it one by one with a HardDisk cable
RX resistors for Winstar12864B are R37:2.2K, R40:6.8K
2- coil resistance can be between 3-4R, inductance need to be minimum 400-500uH,
dampening resistor for coil need to be 680R metalfilm 2W
3- schottky can be byw29e, if you cant't find this part make it short circuit
4- see 12V at VD7 pin
5- points need to see 5V
- PIC pin 11
- U3(4094) pin 16
- GLCD pin 14
- the jumper just under C25
6- jumper the pins of PIC 11 and 8 (IC powers activated)
don't forget to remove this jumper after test
7- points need to see 12V
- D3 (TL062) pin 8
- D2 (TL062) pin 8
- U2 (4051) pin 16
- R60
- D1 (4066) pin 14
- the jumper over C12
- D5 (4066) pin 14
8- points need to see -E (1.4V)
- D2 (TL062) pin 4
- D3 (TL062) pin 4
- D7 (TL062) pin 4
- D4 (LF356) pin 4
- D1 (4066) pin 7
- D5 (4066) pin 7
- the jumper below R14
- the jumper between C28 and C29
- Q3 S pin
- Q4 S pin
9- put all ICs except PIC and GLCD
10- points need to see +E
- D7 (TL062) pin 8
- D4 (LF356) pin 7
- D6 (TL082) pin 8
11- adjust TR1 to see 6.22V at D6 pin 5
12- points need to measure 180Hz
- VD10
- R84 and R90
- R85
- D1 (4066) 5,6,12,13 pins
13- you need to see 5.3V at D3A, 1st or 2nd pins
this measurement need to be done between opamps - or + supply pins
forexample you can measure between D3 pin 1 and D2 pin 4 or pin 8
if you can't see this measurement
problem source can be one these:
- VD12-VD15 diodes damaged
- R78, R83 100K resistors are not true
- D3 opamp damaged
14- TE9 line (t1 collector) need to between 7-9V
if not, problem source can be:
if gain high TE9 line can be greater than 11.2V
if gain is low 2N7000s or 4066s are damaged
