My Digital Pulse detector Delta Pulse 3
  • Hi Jap
    I adj TR1 Many times but no result ( the line always remains horizontal ).
    I inform you that I used (VD13=1N4007) because I did not find 1N4001
    What is your opinion ???
    • Hi volcano
      -VD13=1N4007....OK
      best time
      j.
      • hi jap
        beraka allah fik
        • thank you Jap
          We have the wedding of my brother in these days
          I see you next week..... ok
          thanks
          • Hi Jap
            I test +E, I find it =2.1V
            I think that the IRF9540 is damaged
            • PI Coil question
              Originally posted by jap View Post
              Hi eaglewings35
              because two coil must The match in the specifications ohm , uh.
              -So you are using 2 coil do not match so it must control every time when you change the coil.
              best time
              j.
              HI JAP, The coil I have is a Whites TDI (PI) coil. It is a double coil, which I understand will not work.
              My question is this.....
              If I cut (disconnect and take out) the inner coil, making it a mono coil, would it then work?
              The coil would then only have 1 coil, not 2.
              Make sense?
              • Hi eaglewings35
                -is inner coil ohm, uh ok?
                -DP3 has the sensitivity to coil ohm, uh----if not---> u gite (error connect the coil) on lcd!!!
                -for Whites TDI (PI) coil see link:
                http://www.geotech1.com/forums/showt...il-White-s-TDI
                best time
                j.
                • Hi all. I have just finished my hardware, waiting for the full hex. I have tried the demo, and all seem to work correctly. But the display works bad.
                  I have a GDM12864H, and i have read here that the H series doesn't work with the DP3.
                  I found two LCD:
                  12864A -> https://www.distrelec.it/ishop/Datas...-n_eng_tds.pdf
                  12864B -> https://www.distrelec.it/ishop/Datas...-n_eng_tds.pdf
                  Are they OK? What's the difference between the A/B and the H series?
                  Thank you
                  • Hi jap
                    I changed the IRF9540 and IRF740, VD12, VD13,VD15
                    But I have already the same problem ( +E=2.1v)
                    please Help me
                    • Hi volcano
                      -OK ,,,
                      to get -E,+E,,,
                      --RE, IN PHOTO in reply#281 ,there Open its cotroll ON it come from the PIC -----> FOLLOW pdf to test +E=12v.
                      Hi DianaBlu
                      -U say,, all seem to work correctly. But the display works bad...HOW..???????
                      best time
                      j.
                      • Jap,
                        I dont know the Ohms or Uh. I will take the coil to an electronics shop and have them tell me.
                        Then I will post here and let you know.
                        Thank you
                        • Iv given up on mine cant get it to work
                          • Hi erdin
                            More clear
                            best time
                            j.
                            • Ok i have made some progress. but i have a question when i shot pin 1 and 6 on header 6. this switches the DP 'on' Is this the correct way?
                              • Hi erdin
                                -yes its power on.
                                best time
                                j.
