My Digital Pulse detector Delta Pulse 3
  • it switch's on but the button does not switch it off again. i have to keep disconnecting the battery is this what you are doing as well?
    • now when ever i switch it on i get a message saying ''bobin takili degil'' which i think means coil is unplugged but it is actual pluged in? and nun of the other buttons work? it was working befor?
      • Hi erdin
        -yes its Another sw to off.
        -a message saying ''bobin takili degil'' its normal test ohm ,uh of your coil.
        best time
        j.
        • Thanks jap every thing is working but i can not get tr1 to give 6.22v at pin 5 of d6. What do you think
          • Hi erdin
            -1-test , change D4,D1,D6 AS PDF.
            -2-IN MODE scope use tr1 for calibration.
            best time
            j.
            • Originally posted by turboaleks View Post
              @biogas,
              take care, that the controller of the GLCD is KS0108. There are other controllers on some GLCDs that dont work with programmed pic. I bought one at ebay as mini 12864, which has this controller and its size is only 54x50mm so that it fits in several boxes. the other "standard" displays i would have to mount on the top of my box, what i didnt want, hehe. Mentioned GLCD costs 13 Euros incl. shipping.
              Hi!
              Where can I that buy it? Please post it the netstore!
              Thx
              Biogas
              • Hi Biogas,
                here is the ebay link to that LCD:
                http://www.ebay.de/itm/160375870532?...84.m1497.l2649
                You can choose between 3 colors.
                Gruß
                  Hi Biogas,
                  Gruß
                  LCD
                  Ok, thank you! (Vielen Dank! )
                  It has light on/off function?
                  Battery
                  Wich battery need this detector? 12V? For example 2500 mAh 10 x 1,2V AA battery in pack? Or?
                  http://www.google.hu/imgres?hl=hu&sa...9,r:2,s:0,i:74
                  Switch
                  I would like build a" water/drop/splash" proof detector. Witch switch are the ideal for it?
                  I think it's don't the best for it!!??!!
                  http://www.ebay.co.uk/itm/12v-Push-B...item3f1a51ad7f
                  Coil
                  I would like build about a D40 coil, and a 1x1 frame coil. Which properties have they coils (wire D, numbers of turns, industance, resistance, etc)?
                  Schematic
                  I don't find a high-resolution picture about PCB and schamtics. Have anyone?
                  Many THX!
                  BR
                  Biogas
                  • Originally posted by jap View Post
                    Hi erdin
                    best time
                    j.
                    Hi jap, can you expline a litle what you mean by ''IN MODE scope use tr1 for calibration''
                    • Originally posted by erdin View Post
                      Hi erdin
                      -Read reply #180
                      best time
                      j.
                      • @ Biogas,
                        the LCD has a backlight function at pin 19 and 20, which is controlled by the PIC18F452. So when you push the main switch on, after initalize the backlight turns on.
                        I power the MD with an external power supply (12V and 7,2 Ah). It is your choice how to assemble it.
                        If you want to have a water-drop-splash-proof MD, the box, the 5 control buttons, connector(s) have to have these specs,too. Even the common LCDs do not fulfill this condition.
                        The level of protection you mentioned is about IP64 so i would search for this in the technical informations.
                        I built my coil like this:
                        wire: 3meters of CAT5e (standard ethernet)
                        turns: 3 (diameter about 31,8 cm)
                        inductance: 473uH
                        resistance: 3.6 Ohm
                        Generally resistance should be in 3-4 Ohm range and inductance 400-500 uH ( i also read 400-600 uH).
                        The PDF docs in the author“s forum were good enough to etch the PCB and see clearly all components, at least for me.
                          Hi erdin
                          -Read reply #180
                          best time
                          j.
                          Hi jap,
                          thanks for your reply. I watched the video but i dont understand how it will help me set tr1 up?
                          • Hi erdin
                            -RE,in MODE scope u can adj. tr1 for calibration.(to get the Curved u see)
                            -test , change 2n7000, D4,D1,D6 AS PDF.
                            best time
                            j.
                              Hi erdin
                              best time
                              j.
                              Ok jap, il give it a go. thk you
                                @ Biogas,
                                inductance: 473uH
                                resistance: 3.6 Ohm
                                Hallo!
                                Thank you the response! It was useful!
                                Have you finished your projeckt? Can you share photos? If not, than tooo! Thank you!
                                I have problem with the LCD light: in our country must/ recommended/safe detecting in dark/night, than I don't need the LCD light...
                                This D30 coil I think it is to small for me , than I would like a bigger coil! (Have you tested this D30 coil?)
                                Have anyone technical parameters for D40 coil,and for 1x1 frame coil? (turns, wire typ, etc) (I see: 3-4 Ohm range and inductance 400-500 uH)
                                Where is the conecting points the coils and between the PCB? "Bobin"? Wich plug/connentor need I to? 4 pin, 5 pin, or a special?
                                Under LCD are 2 resistor whit RX value, what are they? If resistor, wich value need I?
                                I found good PCB and schematic....... in my folder...
                                And I would like buy the parts, but I don't have the real part list,have anyone?
                                I have a plain,but this have a lot of imformation, and I would like see clearly for example:
                                - C1 18 pF...C39 100 nF
                                - R1 4K7...R91 1k
                                Or:
                                Resistors:
                                -5K6 11piece
                                -1K5 5piece
                                Capacitors:
                                -47 uF 5 piece
                                1
                                0000 uF 2 piece
                                Many thanks!
                                BR
                                Biogas
