Hi Biogas,
I can post some photos maybe this weekend, too busy at the moment. For D40 and 1m coil i read a post on page 3. You could ask for further information.
As you already wrote, "bobin" is the coil. There are so many connectors out there, depends on where it is easiest for you to get (for coil minimum 2 pins, your choice).
The 2 resistors marked with "x" are for for LCD contrast. Their values depend on the display you use.
With a higher value for R43 you can "darken" it.
Here is a partlist:
Comment Designator Quantity
BESLEME- BESLEME+1 1
3~4 R BOBIN1 1
47pF C1, C12 2
18pF C2, C3 2
15pF C4 1
100nF C5, C6, C7, C8, C9, C10, C11, C14, C16, C18, C21, C23, C26, C32, C33, C37, C39 17
10uF Tantal C13, C29, C38 3
220nF C17 1
1nF C20 1
1000uF C22 1
470uF C24 1
47uF C25, C27, C31 3
220uF C28, C30 2
100uF C34 1
10000uF C35, C36 2
KIRMIZI Charge1 1
4066 D1, D5 2
TL062 D2, D3, D7 3
LF357 D4 1
TL082 D6 1
D Schottky D8 1
speaker J1 1
LED P1 1
128*64 GLCD P2 1
Yedek Akü P3 1
Sarj P4 1
Header 6 P5 1
200K PR1 1
2N7000 Q3, Q4 2
IRF9540N Q5, Q9 2
bs250 Q6 1
IRF740 Q7 1
SCR BT169D Q8 1
4K7 R1, R2, R7, R12, R17, R18, R33, R41, R57 9
3k3 R3, R5, R8, R13, R15, R19, R21, R76 8
47K R4, R14 2
10K R6, R26, R32, R52, R53, R55, R59, R61, R71, R79, R84, R88, R90 13
120K R9, R16 2
100K R10, R31, R38, R39, R47, R66, R72, R78, R83 9
2K2 R11, R69 2
1K R20, R27, R60, R65, R67, R81, R85, R89, R91 9
560R R22, R24, R25, R30, R34, R44, R73 7
56K R23, R46, R48 3
12K R28, R86, R87 3
22K R29, R42 2
1M R35, R36 2
RX R37, R40 2
49R R43 1
90K R45 1
5K6 R49, R51 2
330R R50 1
680R R54 1
680R R56 1
8K2 R58 1
1K5 R62, R68 2
470R R63, R80 2
150R R64 1
180R R70 1
1R8 R74, R75 2
47R R77 1
100R R82 1
BC546 T1, T2, T3, T4, T5, T6, T9, T12, T13, T14, T15 11
BC557 T7, T8, T16 3
2n2907 T10, T11 2
10K TR1 1
PIC18F452 U1 1
74VHC4051N U2 1
HCC4094BF U3 1
7805 U4 1
1N4148 VD1, VD2, VD4, VD5, VD6, VD7, VD9, VD10, VD11, VD12, VD14, VD15, VD16 13
8V2 VD3 1
10V VD8 1
1N4001 VD13 1
15V VD17 1
20MHz X1 1
Here is a partlist:
3~4 R BOBIN1 1
47pF C1, C12 2
18pF C2, C3 2
15pF C4 1
220nF C17 1
1nF C20 1
1000uF C22 1
470uF C24 1
220uF C28, C30 2
100uF C34 1
10000uF C35, C36 2
KIRMIZI Charge1 1
4066 D1, D5 2
TL062 D2, D3, D7 3
LF357 D4 1
TL082 D6 1
D Schottky D8 1
speaker J1 1
LED P1 1
128*64 GLCD P2 1
Yedek Akü P3 1
Sarj P4 1
Header 6 P5 1
200K PR1 1
2N7000 Q3, Q4 2
IRF9540N Q5, Q9 2
bs250 Q6 1
IRF740 Q7 1
SCR BT169D Q8 1
47K R4, R14 2
120K R9, R16 2
2K2 R11, R69 2
56K R23, R46, R48 3
12K R28, R86, R87 3
22K R29, R42 2
1M R35, R36 2
RX R37, R40 2
49R R43 1
90K R45 1
5K6 R49, R51 2
330R R50 1
680R R54 1
680R R56 1
8K2 R58 1
1K5 R62, R68 2
470R R63, R80 2
150R R64 1
180R R70 1
1R8 R74, R75 2
47R R77 1
100R R82 1
BC557 T7, T8, T16 3
2n2907 T10, T11 2
10K TR1 1
PIC18F452 U1 1
74VHC4051N U2 1
HCC4094BF U3 1
7805 U4 1
8V2 VD3 1
10V VD8 1
1N4001 VD13 1
15V VD17 1
20MHz X1 1
