My Digital Pulse detector Delta Pulse 3
  • Originally posted by Freelander View Post
    Nicolas: As reference I received from Pasha 6 meter Cat6 containing 8 wires, but only 6 are connected in order to get 3.6 ohm. (3.6= total ohm including the low noise cable)
    Please Mr Jap give me idea about the appropriate Battery to use.
    Good luck all.
    hi FREELANDER
    THANK YOU VERY MUCH
    BEST TIME
      Good luck all.
      Thank you Freelander
      But how the diameter of the coil 6 meter ?
      and see if DP3 now detect the coil and metal ......
      • Nicolas: Off-course the coil is detected but outside.
        Lets try with 4 turns, fix an object and make trials.
        Once I will found the conform battery I will go ahead outside with my device for trials, then I will give you feedback.
          OK thank you I understand for what it's detected the object when I put it in the center of the large 1mx1m frame
          I or a neighbor electric fields as my magnifying glass ... see my pictures on previous pages
          http://www.teknolojiekibi.com/yeni/i...opic=3797.4060
          ok I'll try it outside.
            Good luck all.
            Hey Freelander, I bought one of those 12V 9800MaH batteries (China Made), but it still did not have enough power to run the DP3. I finally found out that you have to find a battery with a minimum of 3 AMPS. Once I did this, my detector worked fine. Hope this helps you !!!
            • Hex file to the device is limited.
              Does anyone have the correct file?
              • Programmed Pic microprocessor can be ordered from the Author.
                • Originally posted by eaglewings35 View Post
                  Thank you friend Eaglewings, Here we are sure this MaH indicated value is not real, It's a matter of fraudulence from those unknown suppliers.
                  • Originally posted by reza vir View Post
                    Hi
                    You can buy it by contacting Pasha.
                    • I'm living in Iran
                      Sanctions can not be purchased due to communication and
                      • Hello JAP, I did a 1m x 1m coil, the coil can detect, but the detection range shorter than the small coils, I do not know why, I ask the the 1M coil needs much about how many laps is the best effect is the diameter,Do not change the bigger coil the resistance R54, R56 many watts?
                        • Originally posted by liudengyuan View Post
                          Hi
                          You may describe your small coil please
                          I see this DP3 is the same DP2 so do not waste your time and your money. it is not a good detector.
                          Good luck to all
                          • Yes, I feel DP3 does not the Delta Pulse then the utility can not tune the frequency, pulse width can not be adjusted, not cleared button, when the case of instability, the noise is very troublesome, can not handle.So, and the coil is hard to configure
                            • I need full hex for DP3 English
                              Three times he sent an email to Pasha not answer
                              • I built dp3 work with demo hex file
