My Digital Pulse detector Delta Pulse 3
  • Originally posted by moscadondres View Post
    Hi Jap,
    I would like remove the charger on DP3( all componants),but how i have to connect pin 16 of pic,thank you for help.
    No need connect to another elsewhere
    • Hi mrmr16,
      Thank you for reply but why connect one 2N7000 pin2 and others .
      • Originally posted by Nicolas View Post
        Hi friend Forget that
        The DP3 is a bad detector and not stable and have same problem for evryone not sicces for all
        The turk now work for a other DP3
        Look it
        http://www.teknolojiekibi.com/yeni/i...opic=3797.4320
        hi niolas
        is Dp3 solve this problem?
        • hi my friend..i am new user in page...i need to dp3 hex file,,,,can you help me?
          • hi mr babak . you can buy pic via original hex program via karadag user in teknolojiekibi site . if you are in Iran , you must be pay 30$ in huseyin demirs paypal account and he send you a pic . if you are in Iran you can buy a original pic in iranian site.
            • hi mohandes . yes the stably problem solved in new version of dp3s. and new version is very stably .
              MOhanses i am from Iran , if you have problem about dp3 you can send me private massage .
              • Originally posted by hadi-dindar View Post
                Hi hadi
                Nicolas says dp3 not good!!what is your idea?
                • Hi Friends,
                  Delta Pulse 3 is a stabil detector as all delta pulse series and delta pulse copies. But, some peoples may be experiencing some problems about stablitiy due to automatic analog tune or faulty manufacturing or coil. For example some people using not rigid 1x1 meter coil and when coil yawns detector begins to signal. This is not detector or design fault. This is manufacturing fault. A lot of people are using tihs detector on the ground now without any problem. Sometimes some people send me some their delta pulse 3 detector that home made for repairment. And I saw a lot of problem on the boxing, or connecting or soldering or etc. on the detectors. So, I developed a new detector to solve stability problems and to simplify manufacturing. This detector has digital tune feature and very high stablity on the ground.
                  About Delta Pulse 3S,
                  This detector is entirely different detector. Only name is delta pulse 3. Circuit, softwere, working system all parameters is different and newly developed. Also, I am working on a PC software for DP3s for vizualization. You can examine from following link but you should become member to see photos and attachments.
                  http://www.teknolojiekibi.com/yeni/i...p?topic=4900.0
                  Regards.
                  • hi pasha
                    ok
                    i want to make dp3(that you send)
                    we should just use coil 1m*1m???????????
                    • hello hadi
                      if i want make dps3 an you help me?
                      are you ACQUIESCENT at this detector?about depth and ,...
                      please tell me ok or no
                      thanks
                      • dear pasha iwant delta 3 hex file please help me my email [email protected] please pasha bhai meri madad zaroor ki jiye i am new
                        • rais.mumbai , hex file is not free . you must buy it .
                          go to http://www.teknolojiekibi.com/yeni site .
                          • Hi,
                            This is our new detector.
                            • How much Delta Pulse 3s full kit ready for hunt
                              • whether it is possible sending programmed controller Russia and how much will it cost?
