My Digital Pulse detector Delta Pulse 3
  • hi all friends and my best friend jap
    i need the lyt format of pcb . i want to edit this pcb . i cant print this pcb on board . plz send me lyt format of dp3
    • Hi hadi-dindar
      None at now lay.out format of pcb of DP3.
      --u can make it.
      best time
      j.
      • can you send me the original pcb with thin line in compacts space.
        • Hi hadi-dindar
          I do not understand ? explained more,,,
          best time
          j.
          • i cant print pcb on fiberglass fiber
            i download original pcb from turkish site
            but in this pcb the line are very Thick in Compact areas.
            i need a original pcb with Narrow lines in Compact areas.
            • Hi hadi-dindar
              How to make PCBs at home
              in 1 hour & W I T H O U T special materials
              ---- http://www.riccibitti.com/pcb/pcb.htm
              best time
              j.
              • Hey J. I was just wondering if each time I changed the search coil (30 and 50) do I have to
                change the settings?
                Why cant I use the dual coil? (Whites TDI coil)?
                Thanks Kerry
                • Hi eaglewings35
                  because two coil must The match in the specifications ohm , uh.
                  -So you are using 2 coil do not match so it must control every time when you change the coil.
                  best time
                  j.
                  • Hi all, I have just some questions:
                    The P3 and P4 connectors are about "battery charger" and "backup battery", but how to connect them? I've seen a hires photo, and seem that P4 was jumpered pins 1-2, and P3 is not well visible.
                    "Charge1" led under the first 10000uF capacitor lights when...?
                    What's about the meaning of the two front panel leds?
                    • Hi Pasha!
                      I payed with PayPal on 10.12.2012. 41 Eur for Delta Pulse PIC, and PCB!
                      Please write me, this pack have you yet sending for me,or not??
                      Because I haven't got answer im PM from you, but I wrote to you 3-4 times already in this themen!
                      Thank you!
                      I'm waiting the answer and the Packet!
                      Biogas
                      • Hello Jap, and all members of this forum.
                        I use the software "Picpgm" to program the pic18F452.
                        I have upload a picture of this software.
                        Now, please tell me :
                        the box must be checked.
                        and.
                        the box must not be checked.
                        • Hi volcano
                          see rar.
                          best time
                          j.
                          • hi volcano the rar that you have uploaded needs a password
                            thanks
                            • Originally posted by jap View Post
                              Hi volcano
                              see rar.
                              best time
                              j.
                              Hi, Jap you do not understand me
                              I asked
                              what are the boxes must I check
                              1-program code memory (flash)
                              2-program data memoy (eeprom)
                              3-program ID location
                              4-program configuration Bites
                              • good day
                                hi everyone
                                please and please i wont to know if any one can send me a programed pic to Syria or Lebanon and please if any one knows somebody that is near to me and can help me in the pic tell me about him or if any one can send me the hex file and i swear i will not use it for commercial use i dont how much you will belive me but its the truth
