My Digital Pulse detector Delta Pulse 3
  • Originally posted by turboaleks View Post
    Thank you Volcano. I hope you will finish your DP3 soon.
    Hi turboaleks
    can you upload a test video of your project ?
    • Hi there pasha,
      I tryed to go at the site where you sell the DP3 but i couldnt buy it directly from there or i got sorta confused with the site.
      Can anyone enlight me how i can contact with someone to ask some details and stuff about it?
      Skype maybe?
      Thanks in advance,
      A.
      • Hi All!
        What is the KIRMIZI Charge1 1?
        Thankx
        Biogas
        • Hi Jap
          it remain a one problem
          the PIC can not detect the coil.
          the IRF740 is very hot when I connect the coil.
          I can not get this bandwidth.
          I found BS250 is damaged; I changed it
          But I have the same problem.
          thanks
          • Hi volcano
            -see 1,2,,,,,8
            best time
            j.Click image for larger version
            • Thank you Jap
              I will try
              • Hi Jap
                I have done everything that you said to me.
                I did not do just one thing ( I do not change 680 ohm 3, because I have not it ).
                Unfortunately remains the same problem.
                thanks
                • Hi volcano
                  Test & change that part
                  best time
                  jClick image for larger version
                  • thank you Jap
                    I will try.
                    just a question :
                    how can I delete the charger part from PCB ( what straps, I will cut it from PCB ) ???
                    and I will sent a private message ( pictures of my DP3 )
                    • Originally posted by volcano View Post
                      just a question :
                      Hi volcano
                      xxxCHARGING LISTxxx
                      -R57,58,62,64,68,69,70,73,74,75,76.
                      -C20,27,31.
                      -T7,8,13
                      -VD8,9,11,14,16
                      -Q8
                      -PR1
                      best time
                      j.
                      • Originally posted by jap View Post
                        Hi volcano
                        xxxCHARGING LISTxxx
                        -C20,27,31.
                        -T7,8,13
                        -VD8,9,11,14,16
                        -Q8
                        -PR1
                        best time
                        j.
                        So I remove all this components.
                        or cut straps on PCB, to isolate all charging components
                        • remove all this components
                          J.
                          • Hi Jap
                            for T10 T11, I understand
                            But, what I do for : 74HC4094, HCF4051 ( I will change them !!!!! )
                              Hi Jap
                              Hi volcano
                              -for T10 T11------->irf740 gite work
                              - for : 74HC4094, HCF4051 --->read part 6 in reply#197------>U must change!!!!!!!!
                              best time
                              j.
                                Hi volcano
                                best time
                                j.
                                Hi Jap
                                there is nothing into replay 197
