My Digital Pulse detector Delta Pulse 3
  • Originally posted by jap View Post
    Hi pigeon
    -U can not replace with [BU406D/BU426A/BU508A/BU807] its TR.
    -BT169D its SCR.
    ---For assist Download datasheet of BT169D & replace it In relation to the V,A,,With Note arrange of pin K,G,A
    best time
    j.
    hi jap
    thank you very much
    best time
    P.
    • hi to all! I always fail programing PIC18F452 in JDM2 programer by WINPIC, what programer that best in PIC18F...families that affordable or easy to make?
      • son düzenleme yapılmış şekli
        • Originally posted by Saromines Ramiel View Post
          Hi Saromines Ramiel
          -try to use picpgm ,will work with JDM2 programer .
          best time
          j.
          • Hi again,
            I see that the coil i have received in kit , has 2,4 ohm. So I have to put 5w1rj resistor, it´s right?
            If is like this, I have a problem, because two cement resistors i have received are 5w2rj and i´m trying to find 5w1rj but i don´t see anywhere in web.
            Can anybody say to me where can i find it?
            Thank you very much.
            • Originally posted by Malibu View Post
              Hi again,
              Hi Malibu
              -You can experiment :-
              1- without .
              2- with one .
              3-with two resistances in parallel .
              And see the result
              ****the true result that when does not display the --coil is not Connected--****
              best time
              j.
              • Hello, DP3 can detect how far away, who do you have a video of it
                • Hello, help DP3 PCB file. Who can help me, my email [email protected] thank you
                  • Hi, I have a question. My DP3 is working ok, but i don't understant the purpose of the two LEDs connected to the 4094. I have seen on a frontal posted something like "FERROUS" and "NO FERROUS", but by LEDs are always off.
                    Should they light when something is detected? There is something wrong with my circuit?
                    Thank you
                    Max
                    • Hello DIANABLU, you can I have the DP3 's PCB file, thanks
                      • Originally posted by liudengyuan View Post
                        Download it HERE
                        • hi to all friends
                          i want to print the pcb of dp3 on board . but the size of this pcb wrong.
                          i cant match pins of pic with pcbs pins . plz send me correct pcb for print on board.
                          regards .
                          • Originally posted by DianaBlu View Post
                            Max
                            Hi DianaBlu
                            -May be the two LEDs connected wrong.
                            best time
                            j.
                            • Originally posted by hadi-dindar View Post
                              hi to all friends
                              regards .
                              Hi hadi-dindar
                              DeltaPulse3PCB 16.5cm x 11.5 cm.
                              from pdf print true size.
                              best time
                              j.
                                hi to all friends
                                regards .
                                Hi hadi-dindar
                                Print the PCB with scale 100%
                                Best time
                                Nicolas
