SD2000
  • SD2000
    Hi there. I have a question to colleagues. Someone did you drive the SD2000. Thank you.
    SD2000
    Obviously the topic is difficult . I have attempted to create PCB of this device. It was a pretty well-at least I think so. But I can not implement them due to lack of time. Rose 3 PCB with dimensions 100 mm X 140 mm. There are some errors but time will tell. Can anyone say whether it is worthwhile to copy this unit. Thank you . Sorry for bad English but translated by google translator
      Hi you could not imagine how difficult is to draw good PCB for SD2000,
      Building SD2000 is more then worth you will see .
      Detecto
        SD2000
        I made boards DIP elements but I'm not sure it will work. Bothers me that the scheme has some inaccuracies. I think it gradually revived and began the first of the power module and sound-they are on a board. The second is the generator of the transmitter. The third PCB is the receiver, demodulator and filters. Google translator is ......
          Hope i unerstand you
          You can't use DIP packages for SD2000....
          this picture will help you....
          Detecto
            Thanks, Still Picture these have them. We see our baby and I can not write anymore ...
              Detecto
              Your statement seems to predicate that their is an accurate schematic/PCB pair available.
              If so, could you or somebody please post a link to said schematic/PCB pair?
              With due respect to those who seem to have had some measure of success with cloning the SD2000, there is not a lot of super reliable data (especially considering the complexity of the project. Maybe I've missed something.
              Forgive me, but I have my doubts.
                SD2000
                I understand your doubts Porkluvr I think so, but I will try
                  Well, I wish you success. Maybe YOU will be somebody who can post a correlated PCB / schematic combination, with a "thumbs up".
                  I just don't believe what I've seen so far, it's been too fragmented.
                    You can do it!
                    Zed' schematic is correct as i have got my clone working. Do not use other schematics as they are incorrect. Hole thru parts can be used apart from a few parts that are only smd. Download all data sheets for all parts and study them. This is a difficult, fustrating, costly & time consuming project, but rewarding when completed. I highly recommend that you use a minelab monocoil.
                      how was the approximate total cost for this project ?
                        To build 2 x double sided pcb's and fitted inside a Hammond alum. enclosure cost me approx. 470 US dollars. That includes pcb iron sheets, etching solution, solder and pcb cleaner.
                          Is you'r SD2000 quiet like original?
                          If you used BYV28-200V they have about 240-250pF of internal capacitance try to use MURS320 its have abouth 110pF internal capacitance
                          GPX3500 use MURS320 as FRD.
                          Cheers
                          Detecto
                            That total cost does include coil , battery ? Or just the components ?
                            I want to try it too
                              The final product looks good,
                              Wonder if its possible to create a field test video and share it on YouTube
                              Would be interesting to see the performance and how close it comes to the original
