Hi
I'm trying to export Data on a .sl2 file to the .csv format using Sonar Log Viewer from Lowrance. The data was collected using Lowrance HDS7 Gen2 touch. Previously, exporting the data worked fine using the "output chart information" function in Sonar Log Viewer. Now I have ten .sl2 files that don't export properly. The .csv file is created but contains only about 60 lines with data. The data displays properly in Sonar Log Viewer, all the data is there. It is therefore a problem with the export function. I guess it has something to do with changed settings on the HDS device.
I can't find any other software wich is capable of converting .sl2 to .csv. I only need to get all the depth data and coordinates out of the .sl2 files.
Any help would be much appreciated!
