Lowrance PD-N transducer
  • Lowrance PD-N transducer
    Hmmm.. previous post seem to have dissapeared.
    So here it is again.
    I am looking for the datasheet of the Lowrance PD-N 192 kHz 8 degree transducer (Lowrance partnumber 90-42)
    If you have data on this transducer could you place it on this forum or email/fax it to me ?
    Faxnr: +31 (0)172 216620
    (Please state if it is allowed to put the data on forum.)
    Jan Haarbrink
    Re: Lowrance PD-N transducer
    Not much info on the Lowrance web site. Try sending them an e-mail. I doubt there is much you'll get other than a 192 kHz pod style, 8 degree conical beam.
    What the interest in such a narrow beam?
    Patrick
    >Regards,
    > Jan Haarbrink
      The narrower the beam the more detail I get.
      I've send them an email... but no answer yet.
      Jan.
      >Patrick
      >>Regards,
      >> Jan Haarbrink
        Jan,
        Dan mentioned that with the 20 degree transducers he was able to get a beam pattern of approximately 19° vertical and 3° horizontal. I don not know how he determined this.
        If this is correct, I would imagine that the pattern of an 8 degree transducer would be way too small for our applications.
        Your thoughts?
        Patrick
        >Jan.
        >>Patrick
        >>>Regards,
        >>> Jan Haarbrink
          >Jan,
          I am writing a small basic program than will tell me what will be lit by transducer given the tranducer angle, transducer cone and height above ground.
          I desperately need the datasheets to see how the soundcone is shaped... but allas.. lowrance has not replied yet.
          >Your thoughts?
          >Patrick
          >>Jan.
          >>>Patrick
          >>>>Regards,
          >>>> Jan Haarbrink
