[img]../images/my_recovery_1996.jpg[/img]
JUST SO YOU KNOW, YOU WILL NEVER, I REPEAT NEVER OBTAIN ANY USABLE IMAGES USING FISHFINDER DUCERS.
YOU NEED .2 DEG TO 1.5 DEG 40-60 DEGREE DUCERS
YOU ALSO NEED 750 VOLTS DC TO RUN THEM OTHERWISE YOU WILL NOT HAVE ANY ABILITY TO IMAGE SUBTLE ITEMS.
YOU NEED A VERY GOOD FILTER TO GET RID OF SONIC PULSES IN THE WATER THAT ARE AT THE SAME FREQUENCY AS SIGNAL.
YOU NEED TO CONTROL PULSE LENGTH(DIRECTLY RELATED TO RANGE RESOLOUTION)
THE BEST YOU CAN HOPE FOR IS A SIDEWAYS LOOKING BLOB OF **** ON YOUR DISPLAY THAT UNLESS SOMEONE TELLS YOU THAT IT IS A SHIP YOU WILL NEVER KNOW WHAT IT IS.RESOLOUTION ALONG TRACK IS USUALLY 1/250TH OF RANGE SETTING JUST SAVE YOUR MONEY AND GET A REAL SYSTEM.
I ALSO KNOW STURE AND HE WILL TELL YOU THAT THE MAIN PART OF A SIDESCAN SONAR SYSTEM IS NOT THE TRIGGER/POWER SUPPPLY BUT THE QUALITY OF THE TRANSDUCERS.
TRANSDUCERS NEED TO BE FOCUSED VERY PRECISLY AND HAVE SIDE LOBE TUNING DONE.
THAT IS WHY SIDESCAN TRANSDUCERS ARE 4-6 K EACH.
THE REST IS BASIC.
A TO D CARDS ARE CHEAP
SOFTWARE IS FAIRLY EASY TO MAKE
BUT YOU WILL NEVER GET RESULTS WITH TOYS, PERIOD.
SAVE YOUR MONEY
THE PIC IS OF MY SBD DAUNTLESS RECOVERY IN 1996 FROM LAKE MIGHIGAN
