Comments to schematic.
  • Comments to schematic.
    The supply is 750V 12mA / side.
    The usage of diodes 13,14,18,19 I don't know.
    The TX 500K transformer is 6 & 39 Turns.
    Sture
    Re: Comments to schematic.
    THANKS!!!!!!!!!!!!!!!!!
    That is great.. I looked over the schematics and was able to read just about everything.
    There were 2 things I was not sure about, so I figured I'd check with you to be sure.
    What is the equation for gain in the upper right hand corner?
    What are the part numbers for A4 through A6? I get CA3080 for all parts, but I wanted to check.
    Thanks again!
    -Bob
      Hi Bob
      >What is the equation for gain in the upper right hand >corner?
      I don't know exactly. In principle it should
      follow th "sonar equation" but I have tested
      to mix with this and found that it is very
      unsensitive. (In my machine )
      I will the the curve on the oscilloscope and write
      the figures.
      >What are the part numbers for A4 through A6? I get >CA3080 for all parts, but I wanted to check.
      It is in fact CA3280 wich is 2 CA3080 in sam case.
      Since CA 3280 is obsolete use CA3080.
      Sture
