Piezos
  • Piezos
    Sture,
    When you say that you tested a bunch of piezos, I was wondering if you have a list of their dimensions and resonant frequencies?
    Also, how do you determine the resonant frequency? do you just apply a pulse and see what the output waveform looks like?
    Thanks,
    -Bob
    Re: Piezos
    I have tested:
    3x5x14 mm around 600KHz
    3x4x50 around 500KHZ
    6x6x50 220KHZ
    2x2x10 don't remember
    3x8x40 620 KHz but different embedding.
    circular 30x15 (151 KHZ)
    The resonant frequency is mainly
    the thickness but the crystals have resonances on
    all dimensions.
    As example the 3x8x40 was ordered to be
    a 600KHz but was finally used at the 8 mm
    resonances 180 KHz (as a experiment)
    The frequency is also depending on wich material
    the crystal is made of. I used medium hard wich
    is the standard Pz5 or Pz27.
    Further more the embedding in epoxy is also
    a factor wich is difficult to calculate.
    To find out the final resonat frequency I have
    done som trial and error.... yeahh lots
    of error.... sure...
    Right now I use 3 mm thickness and 3 mm epoxy
    and this gives me around 500Khz, I can't
    measure the exact frequency since the SCR
    pulse and the following ringing is difficult
    to measure on.
    To find the right thickness of epoxy I
    put a crystal in epoxy and connected a
    transmitter and a oscilloscope.
    The Xducer was then put up with a reflector in
    100mm distance and adjusted for maximum echo
    strenght. Then I grinded off epoxy and looked
    at the echo strenght.
    The result was that the strenght follow a cos
    function (what surprice) and I plotted by hand
    thickness versus echo strenght and at 2.9 mm
    I did have a good maximum.
    Of course this is for my crystals and my epoxy
    but probably it is very similar for other kinds
    also.
    Sture
