My PC.
  • My PC.
    Since I noticed it was some question about how I
    solved my program and PC problem, here it is:
    I use a ordinary desktop PC wich i really a pain
    to carry. I have bought a 9 inch VGA screen to
    have less to carry but it is a pain to look at.
    I want to have a laptop but I wrote my program for
    the graphic card I have and I manipulate it
    trhought the VESA 1.2 standard. This standard
    however is not a standard but only a recommendation
    that the VGA properties should be readable with
    BIOS call. Its differ a lot from card to card.
    I found alse that even if I do the correct call
    to a card it could respond different depending
    on the manufacturer. Finally I didn't care to try
    to write for a card in general, I wrote for my
    Cirrus Logic 5434.
    To scroll my image I change the staring point for
    the VGA card reading its memory.
    To write to the memory I have to define a 64 K
    memory window in the PC RAM wich I map over the
    VGA card memory. This window is then "scrolled"
    over the VGA memory and allows me to write and
    read directly to the VGA memory troght a array
    defined at a absolute adress in the PC.
    The program is written in Pascal and the graphics
    access routines is machine code procedures who
    does the BIOS calls.
    As you may understand, to make this transportable
    to every PC is a lot of work.
    However... he he.. there is no way doing a faster
    scroll than just change the starting point for
    the VGA card.
    Sture
