I might be wrong here but I think the "cap/diode chain" produces a DC output and you want a AC output to generate the ultrasound through the piezo-elements.
Yes, there is a transformer in it.
I just used one I had lying around.
Most small transformers will do, it must just stepup the the voltage.
With the frequency of the oscillator you can adjust the output voltage.
I am not at home at the moment, otherwise I could send you the schematic for the oscillator.
I remember I found thbe schematic on Internet and it is consist only of a few parts.
When you look for Stungun, Taser etc you should find many schematics.
On the URL below you see 3 schematics.
I build one similar to the middle one described here and it outputs 800V (add a capacitor in the output as buffer.)
