Im developing a submarine and want some advice on best sonar for forward viewing of obstacles. Sub is designed for only 30metres of depth.
submarines and sonar
Imaging Sonar Systems
Please check our new Imaging Sonar System
http://www.oceantools.ltd.uk/pdf/sonar.pdf
Alan Craig - [email protected]
Marco,
Give Wesmar a call at 800-772-7620 and ask for Carey J. or email [email protected]. He is knowledgeable about prior systems we have done for naval subs around the world.
Best regards,
Derek A.
I have a Wesmar SS110 sidescanning sonar. It uses a "radar screen" to display the echo returns (CTR tube) with accompanied audio (sound chip) on signals. Controls allow the user to select the angle from straight down to +2 degrees above horizontal, the center of the sweep from straight forward to ~100 degrees on either side and also the width of the sweep from 0 (constant position) to ~300 degrees. This unit will scan from slightly aft of port to slightly aft of starboard and continue this sweep showing the echo returns on the screen. This paints a picture of the botton forward and on both sides out to a distance of 1000' or you can narrow the sweep to any width and select the center of the sweep in any direction. Let me know if you are interested.
[email protected]
